Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Student In Progress
This wiki is being worked on by hardworking students.
Potential Student Project
This page has been tagged for revision by students in our education program.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Respironics (previously Healthdyne) Tranquility Quest and Tranquility Quest Plus are stationary Continuous Positive Airway Pressure (CPAP) medical devices released around 2000 by Respironics, Inc. Designed to treat obstructive sleep apnea, the systems draw room air through rear intake filters, pressurize it via an internal blower regulated by a Main Printed Circuit Assembly (PCA), and deliver continuous airflow through a standard patient tubing connection.
Both systems feature user controls for airflow and an adjustable ramp function that starts therapy at a lower pressure and gradually increases to the prescribed setting. The Tranquility Quest features a ramp adjustment screw and a manometer can be used to read the pressure. The Quest Plus features a Control Panel on the bottom of the unit to adjust pressure and ramp and can be used with the Clinical Remote Control (Model 1703) via the fiber optic communication port on the rear.
Both units feature two system filters, a gray reusable pollen filter and a disposible white ultra-fine filter. The ultra-fine filter increases filtration of pollens, dust, some tobacco smoke, and small particles, and should never be used without the gray pollen filter. Replacement of the ultra-fine filter should be replaced after 30 nights of use or sooner if it appears dirty.
Identification
The Tranquility Quest and Quest Plus are compact, tabletop CPAP machines encased in a two-tone off-white/beige and gray/blue plastic housing. Both units feature the Respironics brand logo and the Tranquility Quest and Tranquility Quest Plus model name printed on the top of the enclosure, a 22mm air outlet port for standard CPAP tubing, and an AC power inlet and removable intake filter cap on the rear panel.
Distinguishing the Quest from the Quest Plus:
  • Tranquility Quest (Model 7300 and 7300H): The base model features simple push-button controls (On/Off and Ramp) with basic LED indicators and lacks a digital LCD screen.
  • Tranquility Quest Plus (Model 7400): Upgraded variant featuring a small LCD display on the bottom panel for viewing pressure settings, compliance meter, and Therapy Menu (not to be used by patients), navigation/control buttons, and a Fiber Optic Communication Port for the Model 1703 Clinical Remote Control (CRC).
To locate the modal and serial numbers, flip the device upside down (after unplugging the power cord) to locate the silver/white label with the model (7300, 7300H, or 7400) being the REF number, SN being the serial number, along with the electrical input ratings (100-120V 75VA/200-240V 75VA 50/60Hz).
Technical Specifications
Tranquility Quest
Environmental:
  • Operating Temperature .......................... 59 to 104°F (15 to 40°C)
  • Storage Temperature ............................. -4 to 140°F (-25 to 60°C)
  • Humidity ................................................. 10 to 95% non-condensing
  • Altitude ................................................... 0 - 7,000 ft (0 - 2286 m)
  • Noise Level ............................................. No specification is given
Physical:
  • Dimensions ............................................. 9.5” (L) x 7.75” (W) x 5.0”(H) (24.1 x 19.7 x 5.0cm)
  • Weight ..................................................... 4.5 lbs (2.2 kg)
Fuse:
  • Fuse Type ............................................... T1A, 250v, 5 x 20 mm
Electrical:
  • AC Input Voltage ..................................... 85 - 260VAC; 47-63Hz
  • AC Current Consumption ....................... 1.0 A maximum
  • Power Consumption ............................... 75 VA maximum
  • Class ....................................................... IIa
  • Type ....................................................... Type BF
Ramp:
  • Minimum Ramp Pressure....................... 3.0 - 20.0 cm H2O
  • Ramp Resolution.................................... 1.0 cm H2O
  • Ramp Time ............................................ 0 - 30 minutes
  • Ramp Time Resolution .......................... 5 minute increments
Pressure:
  • CPAP Pressure ...................................... 3.0 – 20.0 cm H2O
  • Accuracy, Static .................................... +/- 1.0 cm H2O for flows between -60 to + 120 L/min.
  • Accuracy, Dynamic ............................... +/- 1.5 cm H2O for flows between -60 to + 120 L/min.
Environmental:
  • Operating Temperature .......................... 41 to 104°F (5 to 40°C)
  • Altitude ................................................... 0 - 10,000 ft (0 - 3048 m)
Physical:
  • Weight ..................................................... 4.9 lbs (2.2 kg)
Fuse:
Electrical:
Ramp:
Pressure:
  • Accuracy, Static .................................... +/-1.0 cm H2O for flows between -60 to + 120 L/min.
Additional Information
Author
with
scrypt
954 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 534
