Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
Respironics Solo LX and SoloPlus LX are CPAP (Continuous Positive Airway Pressure) machines used for the treatment of adult Obstructive Sleep Apnea (OSA). Recognizable features on the top display of the Solo LX and Solo Plus LX include power-on signal lights, pressure display and elevation setting display. At the back of the model you will find an AC power cord connector, an AC voltage selector and a removable filter tray. When powered on, the Solo LX display may be erratic, indicating that the machine is in need of repair. Using a voltage converter has been known to cause damage to the Solo LX. Model Number M622062E. These devices were patented, produced and available for purchase beginning in 1998. A list of recalled Respironics CPAP devices can be found here.
Important
  • Use only Respironics fuses supplied by your homecare provider.
Included with Original Purchase
  • Solo LX or Solo Plus LX
  • Filter Cap
  • Pollen Filters
  • Optional Ultra-Fine Filter
  • Power Cord
  • User Manual
  • Some Solo LX Systems may also include one or more of the following accessories:
    • Headgear
    • 6 ft. (1.83 m) Flexible Tubing
    • Exhalation Port
    • Nasal Mask
    • Humidifier
    • Carrying Case
  • SoloPlus LX devices are equipped with a time meter. Solo LX devices are not.
Required Items For Use - Sold Separately
  • Flexible Tubing, Respironics 6 ft. (1.83 m) flexible tubing with a smooth inner lumen and a 22 mm inner diameter
  • Exhalation Port (e.g. Whisper Swivel© or equivalent) Note: This is not required if you are using a mask with a built-in exhalation port.
  • Headgear
  • Nasal Mask or other equivalent interface
Warning
Do Not use the Solo LX Solo Plus LX CPAP System until an appropriate professional adjusts the settings!
Technical Specifications
Device Size
  • Dimensions: 10.00" x 5.50" x 4.75" (25x14x12 cm)
  • Weight: < 5 lb. (2.27 kg)
Additional Information
Philips Respironics Device Homepage
Replace Ultra-Fine Filters
Replace Power Cord
Consumer Product Safety Commission Recall Search
Solo LX Solo Plus LX User Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,098
