Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Parts And Accessories
Filter Replacements
Filter Replacements
Exhalation Ports
Exhalation Ports
Face Masks
Face Masks
Replacement Tubing
Replacement Tubing
Background and Identification
The Respironics Remstar LX and LX Plus are known as continuous positive airway pressure (CPAP) machines. CPAP machines are a common treatment for obstructive sleep apnea (when the muscles in the throat relax and obstruct the individual’s breathing). CPAP machines use a face mask and/or nosepiece to continually deliver a steady stream of pressurized air to the patient. This pressurized air essentially “pushes” the throat muscles back to their normal position, so they no longer block the patient’s airway.
Note: The only difference between LX and Plus LX models is that the Plus LX has a time meter.
Technical Specifications
The units incorporate a key pad with two user buttons, a Light-Emitting Diode (LED) signal light, a time meter (REMstar Plus LX only), and a 2-digit LED display. The units may be operated using either AC (115 - 230 VAC) or DC (12 VDC) power.
Dimensions
10" x 5.50" x 4.75" (25 x 14 x 12 cm)
Weight
Less than 5 lb. (2.27 kg)
Operating Temperature
41 - 104° F (5 - 40°C)
Fuse Information and Size
0.8 amp or 800 ma time delay (100 - 120 VAC)
0.315 or 315 ma time delay (230 - 240 VAC)
5 mm x 20 mm
Pressure
4.0 - 20.0 cm H₂O (AC/DC/CPAP Operating)
System Features
  • C Power Connector: Connect to AC power cord.
  • Air Outlet Port: Connect to flexible tubing.
  • Blower On/Off Button: This button turns the blower either on or off.
  • DC Power Connector: Optional DC power connection.
  • Filter: The pollen filter screens out normal household dust and pollens.
  • Filter Cap: The filter cap can be positioned to direct airflow.
  • Key Pad: Includes user buttons, LED signal light, 2-digit LED display and time meter(REMstar Plus LX only).
  • Time Meter: Records hours of operation.
  • 2-digit LED Display: Displays pressure and altitude settings.
  • LED Signal Light: The green light signals when the units are ready for use. The light will go out when the airflow is turned on. A flashing light signals that the units need to be serviced.
Common Problems and Maintenance
  1. Cleaning the filter: The filter should be cleaned at least once every two weeks under normal usage and replaced with a new one every six months.
  2. The REMstar Plus will not turn on: Make sure that the REMstar Plus is plugged into a working outlet. If you are using a DC battery, the battery may need to be recharged or replaced or the fuses may need to be replaced. Contact your home care provider or Respironics for directions on having the REMstar Plus serviced. Please have the device’s serial number ready when you call.
  3. The pressure being delivered feels different: Check the elevation setting to be sure it is set to your elevation. Change the elevation setting if necessary. If the elevation setting is incorrect, contact your home care provider or Respironics for directions on having the REMstar Plus serviced. Please have the device’s serial number ready when you call.
  4. The noise level of the REMstar Plus has changed to include unusual or harsh sounds during operation: Contact your home care provider or Respironics for directions on having the REMstar Plus serviced. Please have the device’s serial number ready when you call.
Additional Resources
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 33
All Time: 811
