Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
Respironics Pressure Alarm is a device that helps medical professionals keep track of what a patient’s respiratory intake is and keep the rate within the normal range. If something is wrong, it beeps and allows the professionals to react and bring you back to normal stage. (This device is used to monitor a patient’s respiratory rate and signal when a patient’s respiration falls outside the normal range.)
Respironics Pressure Alarm is a device that acts in a similar way as your heart rate monitor. Rather than focusing on the heart, this monitors your respiration rate (lungs).
This device is meant to be used by medical professionals, e.g. doctors, nurses, specialists to monitor your breathing rate.
Forrest Morton Bird (June 9, 1921 – August 2, 2015), is the inventor of the first ventilator for acute and chronic cardiopulmonary care.
Technical Specifications
Measurements: 1.5 × 2 in feet for standard house size.
Width: Around 12.50 inches, Along with Depth.
Power: This device contains two sets of battery supplied. Internal and external battery.
  • External: 12 VDC
  • Internal: 12 VDC
  • Charging can be performed with standard house outlet of 120V
Weight: Usually is estimated to weigh under 30 lbs.
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 44
All Time: 1,117
