Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Philips Respironics BiPAP Auto SV is a bilateral positive airway pressure (BiPAP) device that helps to support breathing conditions such as sleep apnea or COPD. It is a noninvasive ventilator, meaning that it can be used in non-medical and medical settings.
The Auto SV was released in January 2010. It is manufactured to be lightweight and easily portable. The device works to reduce airway obstructions and to promote breathing if respiration slows or stops. It can be purchased with a heated humidifier, which helps to mimic the natural introduction of air moisture that typically occurs with respiration.
Some insurance companies provide compensation for BiPAP machines such as this one. Without insurance, the price ranges anywhere from $2,000 to $5,000 depending on a variety of factors.
The Philips Respironics BiPAP Auto SV is currently restricted by the FDA in the United States. In 2021, it and other BiPAP and CPAP machines produced by the company entered a Class 1 FDA recall. Some of the materials that composed these machines were found to break down and produce dangerous chemicals. Philips Respironics is in the process of sending replacement machines to any consumers who own a faulty product. These machines are still available in other countries.
Identification
The Philips Respironics BiPAP Auto SV is sleek and modern in appearance, with dimensions of 15.7 x 19.3 x 8.4 cm (without optional humidifier attachment). The machine's body is rectangular with rounded edges and comes in a variety of colors including gray, black, or white. On top of the body is a screen and knob controls that are used to adjust pressure settings, access the device menu, and check machine specifications. There is a port on the back of the machine that allows the device to be connected to flexible tubing that attaches to the BiPAP breathing mask. The Auto SV can be purchased with optional additions such as a heated humidifier which adds moisture back into the ventilated air.
Technical Specifications
General
  • Body dimensions
    • With humidifier: 29.7 x 19.3 x 8.4 cm
    • Without humidifier: 15.7 x 19.3 x 8.4 cm
  • Body Weight
    • With humidifier: 4.37 lbs
    • Without humidifier: 2.94 lbs
  • Pressure range: 4 to 30 H2O
  • Data storage capacity: On-board: 3 months, SD card: 6 months
  • Filters: reusable pollen; disposable ultra-fine
  • Device controls: liquid crystal display (LCD), control dial/push button
Electrical Connectivity: IntelliBridge EC40/80
  • Voltage: 100-240 VAC
  • Frequency: 50/60 Hz
  • Amperage: 2.0-1.0 Amp
Source: Philips BiPAP auto SV Specs
Additional Information
  • If any potential non-US patients or medical personnel are interested in learning more about the FDA recall of Philips Respironics medical devices, please follow this link for information.
  • The Philips Respironics official page contains additional product information, including contact information and a comprehensive user manual.
  • For a more extensive understanding of BiPAP machines, please review this Johns Hopkins article about the conditions that might warrant BiPAP intervention, as well as the advantages and disadvantages of utilizing one effectively.
Author
with
scrypt
954 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 665
