Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Troubleshooting
If you are having difficulties with the Remington Pearl Pro, refer to this troubleshooting page.
Background Information
The Remington Pearl Pro edition is an average size flat iron, that is used to create different hair styles on all types of hair. This version of the Remington pearl pro is black and white with a built in temperature alert. It has a thirty second heat up with with a temperature lock, it’s improved from previous models. The Remington pro has high grade salon performance, that can heat up to 450 degrees. 7/10 pro stylists agree for the best salon quality.
Specifications
WEIGHT:
  • 1.1 pounds
  • It arrives with the dimensions of 2 x 4.9 x 13.6 inches.
  • It weighs 1.1 pounds
MODEL:
  • Its model number is S9500PP.
PLATES:
  • It provides the professional quality pearl pro infused in the ceramic plates for offering the quality results with perfection.
  • There is a provision of 1-inch floating ceramic plates that cover every section of your hair with precision.
  • Heat Up Time: 15 Seconds
  • Plate Technology: Ceramic
BATTERY:
  • It comes with the provision of 60 minutes Auto Shut Off for better usage.
TEMPERATURE:
  • It arrives with the Turbo Heat Settings to attain the highest temperature for optimal results.
  • It can heat up to 400 degrees Fahrenheit and that too within the span of 30 seconds.
  • Voltage 120 VAC 60Hz
  • Highest Temperature: 450 degrees
WARRANTY:
  • It comes with the three-year warranty.
MISCELLANEOUS:
  • Auto Shut Off: 60 Mins
  • Digital Controls: Yes
  • Hinge Lock: Yes
  • LCD Temperature Display: Yes
  • Number Of Heat Settings: 3
  • Swivel Cord: Yes
  • Temperature Lock: Yes
Additional Information
Remington Pearl Pro Official Product Page
Remington Pearl Pro on Amazon
Remington Pearl Pro on Walmart
Author
with
Aniaya Fillyaw
51 Reputation
0 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 72
All Time: 2,346
