Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background:
Launched on the European market in May 2024, the Redmi Pad Pro is marketed as a premium tablet for all users at a moderate price (349 to 379€ at launch, including special offers).
Its technical specifications are quite interesting: a 12.1-inch screen (16:10 aspect ratio, 2.5K resolution, and 120 Hz display frequency) paired with a Snapdragon 7s Gen 2 (Antutu: 615,824) with 6 or 8 GB of RAM and 128 or 256 GB of storage. The tablet is available in three trendy (pastel) colors: Graphite Gray, Mint Green, and Ocean Blue. Speakers, a selfie camera, and a front camera complete the package.
However, its USB-C 2.0 connector positions it in the consumer tablet market, as it does not allow connection to a display or projector directly, which limits its use for office work, CAD, etc.
At launch, like all Xiaomi products, the Redmi Pad Pro was offered for around 379.90€ with a 30€ discount and the Redmi Smart Pen and Redmi Pad Pro Cover included for free. A Redmi Pad Pro Keyboard is also available at an attractive price for once (± 50€).
Identifying the Redmi Pad Pro:
When holding the tablet in landscape mode, on the front, only the selfie camera in the center breaks the unity of the black frame around the screen. On the back, still in landscape mode: on the top right are two large circles with the rear camera and flash, on the top left is the word "Redmi", and on the bottom left are the CE logos and the crossed-out wheelie bin, plus the mentions "Made in China," the serial number, and Xiaomi's address.
Sometimes in the center, there are stickers with the Serial Number (if there is an IMEI, you are holding a Redmi Pad Pro 5G).
Two model numbers are known for the Redmi Pad Pro:
-> 2405CRPFDC for the Chinese market
-> 2405CRPFDG for the global market
Technical Specifications:
The following information concerns only the Wi-Fi model; the 5G version of the tablet will be covered separately
Dimensions and weight:
Length: 280 mm
Width: 181.85 mm
Thickness: 7.52 mm
Weight (without SD card): 571 g
Processor:
Qualcomm Snapdragon 7s Gen2 (SM-7435AB) (eight cores organized as 4x 2.4 GHz Cortex A78 + 4x 1.95 GHz Cortex A55)
Graphics processor:
Adreno 710
RAM:
The tablet has 6 or 8 GB of LPDDR3 RAM, depending on the options.
Internal storage:
128 GB or 256 GB (UFS 2.2).
SD slot: 1.5 TB maximum (microSD Flash)
Display:
12.1-inch WQHD+ IPS LCD screen
Aspect ratio 16:10
Resolution: 2560*1600 pixels
Brightness 600 cd/m²
Refresh rate 120 Hz
Contrast ratio: 1500:1
DPI: 243 PPI
Screen protection:
Corning Gorilla Glass 3
Sound:
4 Dolby Atmos and Hi-Res Audio speakers
Connectivity:
Wi-Fi :
Compatibility: Wi-Fi 6, Wi-Fi 5, and Wi-Fi 4
Bands: 802.11a, 802.11b, 802.11g, 802.11n, 802.11n 5GHz, 802.11ac, 802.11ax
Functions: Dual band, Wi-Fi Direct, Wi-Fi Display, and Wi-Fi MIMO
Bluetooth :
Version: 5.2
Profiles: AAC/LDAC/SBC/aptX/aptX-HD/aptX-adaptive
Network:
Compatible: IPv6
Ports (placing the selfie camera at the top and the screen facing the user):
On the right:
Audio: 3.5 mm jack port
USB: USB-C 2.0 (to connect the tablet to a screen, you must use Miracast or a dongle like ChromeCast)
2 speakers
At the top:
Tray: - SD slot up to 1.5 TB
Volume button
Dual microphone input
On the right:
Power button
2 speakers
Cameras (both cameras are identical in capacity):
Front camera (selfie) centered on the long edge:
Resolution: 8 MP.
Aperture: 1/4", f/2.28, 1.12 μm
High video resolutions: 1080p 1920 x 1080 30 fps
Low video resolutions: 720p 1280 x 720 30 fps
Rear camera on the top left:
Resolution: 8 MP.
Battery:
Internal non-removable 10,000 mAh battery
33W fast charging
Power supply via USB-C
Sensors:
  • Gyroscope: Yes
  • Temperature: Yes
  • Color temperature: Yes
  • Proximity: Yes
  • Ambient light: Yes
  • Accelerometer: Yes
  • Compass: Yes
  • Hall: Yes
Sources and information:
Xiaomi official website: https://www.mi.com/fr/product/redmi-pad-...
Tablet test at Frandroid: https://www.frandroid.com/produits/table...
Performance and features of the tablet at Kimovil: https://www.kimovil.com/fr/ou-acheter-xi...
Gredin973
2,583 Reputation
1 Guide authored
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 152
All Time: 995
