Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Student In Progress
This wiki is being worked on by hardworking students.
Potential Student Project
This page has been tagged for revision by students in our education program.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
  • The Quantum Rehab Outback is an electric power wheelchair made by Pride Mobility under its Quantum Rehab brand. Unlike regular power wheelchairs that are mainly designed for indoor use, the Outback was built to handle outdoor environments like grass, gravel, dirt, and uneven ground. It has four-wheel drive, larger tires, and a suspension system that helps make traveling over rough surfaces easier. It is designed for people with mobility limitations who want more freedom to travel outdoors without being restricted to paved surfaces.
  • The Outback was introduced in 2024 and is still listed as an available product, so there is no confirmed discontinuation date. There are no publicly available numbers showing how many units have been manufactured or sold. It is part of Quantum Rehab's lineup of power wheelchairs but stands out because of its outdoor use.
  • One important event in the Outback's history was a 2026 FDA recall involving a software issue with its controller. Certain wheelchairs could unexpectedly engage their parking brakes when reminder notifications appeared on the screen, potentially causing the user to fall off of the wheelchair. The manufacturer addressed the problem through a software update. Overall, the Outback is an excellent product for giving wheelchair users more opportunities to access outdoor environments that traditional power wheelchairs may struggle to handle.
Identification
  • The Quantum Rehab Outback is easy to recognize because it is bigger and more rugged than a typical power wheelchair. It has four large 15-inch tires, a padded seat with a tall backrest and headrest, and a joystick controller attached to the armrest. It comes in several colors and patterns, including tan, cadet, and different camouflage options. To make sure it is the Outback model, users can check the Quantum Outback branding and look for the serial number on a sticker located under the rear plastic cover on the back of the wheelchair.
Technical Specifications
  • Manufacturer: Pride Mobility / Quantum Rehab
  • Device Type: 4x4 all-terrain electric power wheelchair
  • Drive System: Four independent motors (four-wheel drive)
  • Maximum Speed: 5 mph standard; optional upgrade to 6 mph
  • Maximum Weight Capacity: 300 lbs. with TRU-Balance 3 seating; 350 lbs. with Q-Captain seating
  • Battery Type: Two Group 27 batteries
  • Battery Weight: Approximately 58.6 lbs. each
  • Battery Charger: 8-amp off-board charger
  • Maximum Travel Range: 16 miles at 300 lbs.; up to 17 miles at 220 lbs.
  • Drive Wheel Size: 15-inch pneumatic tires
  • Suspension: Independent Smooth Ride Suspension (SRS)
  • Ground Clearance: 4.92 inches
  • Turning Radius: 49.2 inches
  • Overall Length: 42 inches (without footrests)
  • Overall Width: 28.82 inches
  • Base Weight: 168.6 lbs. (excluding batteries and seating)
  • Maximum Obstacle Climbing Height: 4 inches
  • Maximum Rated Slope: 8 degrees (14.1%)
  • Braking System: Regenerative and electromechanical brakes
  • Electronics: 120A Q-Logic 3 controller
  • Lighting: Full LED lighting package
  • Optional Features: Power seat elevation, backup camera, and specialty controls
  • Available Colors: Desert camouflage, white camouflage, black camouflage, tan, and cadet.
Additional Information
  • The following links provide useful information about the Quantum Rehab Outback, including its features, technical specifications, maintenance, and known safety issues.
  • 1. Quantum Rehab Official Outback Page
    The manufacturer's official page with information about the wheelchair's features, available colors, seating options, and accessories. This is a good starting point for identifying the device.
  • 2. Quantum Outback Owner's Manual
    A helpful resource for owners who need instructions for operating, maintaining, troubleshooting, and caring for their wheelchair.
  • 3. Quantum Outback Technical Specifications
    Provides detailed technical information such as dimensions, weight capacity, battery requirements, driving range, speed, and motor specifications.
  • 4. FDA Quantum Outback Recall Information
    Official recall documentation explaining the 2026 controller software issue, potential safety risks, and the software update recommended by the manufacturer.
  • 5. Quantum Rehab Owner's manuals and resources
    Provides access to additional manuals, safety guides, and specifications for other Quantum Rehab wheelchair models. This is useful when comparing models or finding replacement documentation.
Author
with
Totally Normal
1,261 Reputation
0 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 55
All Time: 259
