Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
10600BR
Background and Identification
The QEP Tile Cutter model 10600BR is a manual tile cutter designed to cut ceramic and porcelain tiles up to 25 inches long. The tile cutter is engineered by Ishii.
The QEP Tile Cutter model 10600BR is compatible with the QEP 21123Q 7/8-inch scoring wheel and ball bearings. It features a cast aluminum alloy base, stabilizing rubber pads for support, and wheels that can be adjusted to four different heights for different tile thicknesses. The 10600BR model includes a replaceable 7/8-inch tungsten carbide ball bearing cutting wheel that is titanium-coating for durability. The tile cutter can cut wall and floor tile up to 25 inches long, 18 inches diagonally, and 5/8 inch thick. The saw also includes side arm extensions to support large format tiles and chrome-plated steel rails. The 10600BR model also features measuring guides to reduce wasted tile.
The QEP Tile Cutter model 10600BR has a silver-colored frame and a black plate with the name “QEP” in yellow font inside of a yellow diamond shape. Some variants may include an orange handle grip while others include a black handle grip. The cutter’s handle sticks up perpendicularly to its base and runs on two bars placed lengthwise along the cutter’s body. The name “Ishii” is embossed in capital letters at the top of the cutter’s measuring guide.
Technical Specifications
Dimensions:
  • Product Length (in.): 35
  • Product Width (in.): 14
Details:
  • Blade Material: Steel
  • Color Family: Steel
  • Cuts Through: Ceramic, Porcelain
  • Flooring Product Type: Tile Tool
  • Flooring Tool Features: Handle grip, Non-slip handgrip, Replacement blade
  • Material: Steel
  • Maximum tile cut size diagonal (in.): 18
  • Maximum tile cut size rip (in.): 24
  • Product Weight (lb.): 23lb
  • Tile Tool Type: Manual Tile Cutters
  • Tools Product Type: Hand Tool
Additional Information
QEP Professional Tile Cutters 10500, 10600 and 10800 Owner's Manual (EN, FR, ES)
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 27
Past 30 Days: 81
All Time: 4,935
