Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
Puritan-Bennett Tyco Helios (stylized as HELiOS) is a personal oxygen concentration system designed by Puritan-Bennett. Puritan-Bennett is a producer of respiratory products and was initially a medical gas supplier. Puritan-Bennett is owned by Tyco Healthcare. An oxygen concentrator is a medical or industrial device that concentrates the oxygen from either ambient air or another gas supply. Oxygen concentrators selectively remove nitrogen and other gases from the air to provide an oxygen-enriched stream. The name HELiOS can refer to either the Reservoir or the Portable units. The H300 Portable name is also used for the portable unit.
The HELiOS oxygen system is designed as a portable system that can be used by patients up to 24 hours per day. Doctors often prescribe this HELiOS model for patients with Chronic Obstructive Pulmonary Disease (COPD). When using the H300 Portable model with a Standard HELiOS Reservoir, patients will usually require less than one liquid oxygen delivery each month. The HELiOS Universal Reservoir can be used to fill the H300 Portable model and the Puritan-Bennett Companion 500, Companion 1000, and Companion T portable oxygen concentrators.
The HELiOS oxygen concentration system includes a Portable patient unit and a Reservoir. Each component can work together or separately. Both portions of the system include the name “HELiOS” printed on the front of the device.
Technical Specifications
Volume of Liquid Oxygen: Typical: 0.38 liters/23 in³
Weight of Liquid Oxygen at 22 psig (152 kPa) Saturation (typical): 0.9 lbs/.41 kg
Gaseous Oxygen Equivalent (at 1 atm. and 70°F): 308 liters/10.9 ft³
Height: 10.5 in./26.7 cm
Empty Weight: 2.7 lbs/1.2 kg
Full Weight: 3.6 lbs/1.6 kg
Economizer Pressure: 22 psig/152 kPa Nominal
  • (Acceptable Range 20.5-23.0 psig/141-159 kPa)
Primary Relief Valve Pressure: 27 psig/186 kPa Nominal
  • (Acceptable Range 24.0-30.0 psig/166-207 kPa)
Secondary Relief Valve Pressure: 80 psig/552 kPa Nominal
  • (Acceptable Range 75-85 psig/518-587 kPa)
Normal Evaporation Rate:
  • Typical: 1.0 lbs./0.45 kg per Day
  • Maximum: 1.5 lbs/0.68 kg per Day
Typical Fill Time: Warm Unit ≅ 40 seconds
Flow Settings:
  • Continuous Mode: .12, .25, .5, .75
  • Demand Mode: 1, 1.5, 2, 2.5, 3, 3.5, 4
Contents Indicator: Mechanical, spring-based weight scale
Environmental:
* Operating Temp.: -20°C to 40°C, 95% max. relative humidity
  • Storage Temp.: -40°C to 70°C, 90% max. relative humidity
Additional Information
Wikipedia: Oxygen Concentrator
Puritan-Bennett Tyco Helios Product Page
Puritan-Bennett Tyco Helios Review
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 504
