Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Puritan-Bennett Companion 1000/Companion T model is an oxygen concentrator sold by Puritan-Bennett. Puritan-Bennett is a producer of respiratory products and was initially a medical gas supplier. An oxygen concentrator is a medical or industrial device that concentrates the oxygen from either ambient air or another gas supply. Oxygen concentrators selectively remove nitrogen and other gases from the air to provide an oxygen-enriched stream.
The Companion Liquid Oxygen System stores and delivers concentrated oxygen at a rate prescribed by the user. The Companion 1000 and Companion 1000 Transport (T) models are portable oxygen concentrators. The Companion 1000 is a one-liter oxygen concentrator that produces a maximum flow rate of six liters per minute. The Companion 1000 T is also a one-liter model, but it can produce up to 15 liters per minute of oxygen. The portable oxygen concentrator units provides a portable oxygen supply that can be filled from a Companion stationary unit.
The Companion 1000 and Companion T oxygen concentrators are visually very similar. They both feature white plastic housing with an array of slits on the sides. The Companion T model includes the name “COMPANION T” printed in capital letters on the side of the machine. The Companion T includes a grey plastic portion on the bottom of the device, while the Companion 1000 does not.
Technical Specifications
Companion 1000:
  • Volume of Liquid Oxygen (typical): 1.23 L
  • Weight of Liquid Oxygen at Saturation (22 PSIG/152 kPa): 3.1 lb.
  • Gaseous Oxygen Equivalent (1 atm and 70 degrees F/21.1 degrees C): 1058 L
  • Height: 13.8 in.
  • Empty Weight: 5.0 lb
  • Full Weight: 8.1 lb.
  • Operating Pressure: 22 psig
  • Primary Relief Valve Pressure: 22 psig
  • Secondary Relief Valve Pressure: 30 psig
  • Normal Evaporation Rate:
** Typical: 1.3 lb./day
  • Maximum: 1.5 lb./day
  • Fill Time (warm container): 1.4 minutes
  • Flow Ranges:
    • 0-6 L/min (standard)
    • 0-4 L/min (optional)
  • Environmental Operating Temperature: -20 degrees C to 40 degrees C, 95% max. relative humidity
Companion T:
  • Height: 14.5 in.
  • Empty Weight: 5.6 lb.
  • Full Weight: 8.7 lb.
** Maximum: 1.5 lb./day
  • Flow Ranges: 0-15 L/min (standard)
Additional Information
Puritan-Bennett Companion 1000 Companion T Manual
Puritan-Bennett Companion T Specifications
Companion Liquid Oxygen Systems Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 539
