Turntable Noise Floor and Interference Repair
6 Answers 3 Score |
turntable will not turn |
1 Answer 0 Score |
Which pliers to use to change cartridge on a Pro-Ject Debut / X1 TT? |
Documents
Tools
Turntable
'• Belt drive design with low noise AC motor Type Select 3
• Plinth out of MDF in matt black or with glossy black, glossy white, silver and red surface
• 1,3 kg balanced steel platter with felt mat
• Bearing Block 3: Low-tolerance chrome-plated stainless-steel axle runs on a polished ball bearing in a brass bearing housing
• Motor decoupled to reduce vibration
• Special, resonance damping feets
Tonearm 8.6 D
• 8.6" tone-arm with aluminum headshell made aout of one piece
• Inverted tonearm bearing comprises inverted hardened stainlesssteel points and sapphire thrust-pads
• Single-screw fi xing of armtube allows rotation for easy adjustment of needle azimuth despite fi xed headshell
• Silicon damped tone-armlift
Cartridge
• Ortofon OM5e
More info and manuals:
http://www.project-audio.com/main.php?pr...
Pro-Ject Debut III Instructions for Use
Pro-Ject Debut III/Phono USB Instructions for Use
