Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Portacool Cooler model PAC2KCYC01, also called the Cyclone 130 3000, is a two-speed portable evaporative cooler. The cooler uses evaporation to produce cool air for areas of up to 700 square feet, such as an outdoor space designed for five to eight people. This model is designed for outdoor usage and is not an air conditioner. The Portacool Cooler model PAC2KCYC01 can be used to cool down patios, garages, or hobby areas on hot days.
This evaporative cooler uses a centrifugal fan to cool outdoor and open spaces. Users can adjust the cooler’s settings to adjust the air output. It produces 3,000 cubic feet per minute of cooling and includes a water level indicator that shows how much water is left in the machine. A red LED on the control panel tells the user when the water has been fully consumed. A dual water fill option allows for users to manually fill the tank or to make a direct hose connection for continuous, long-term cooling.
The Portacool Cooler model PAC2KCYC01 can be identified by the name “Portacool” in light blue capital letters on the front of the machine. The model number is sometimes printed on the side of the cooler’s grey body. The cooler incldues four wheels for mobility.
Technical Specifications
Dimensions:
  • Cord Length (in.): 144
  • Product Depth (in.): 27 in
  • Product Height (in.): 39 in
  • Product Width (in.): 85 in
Details:
  • Air Volume (CFM): 3000
  • Amperage (amps): 5.6
  • Color Family: Gray
  • Color/Finish: Gray
  • Commercial / Residential
  • Cooling Area (Sq. Ft.): 700
  • Decibel (Sound) Rating: 01-Not Measured
  • Evaporative Cooler Features: No additional features
  • Evaporative Cooler Pad Material: Cellulose
  • Evaporative Cooler Product Type: Portable Evaporative Cooler
  • Horsepower (hp): .90 hp
  • Included: Casters, Motor
  • Indoor/Outdoor: Outdoor
  • Material: Plastic
  • Number of Speed Settings: 2
  • Product Weight (lb.): 100 lb
  • Voltage (volts): 120
  • Water Tank Capacity (Gallons): 16
  • Wattage (watts): 672
Additional Information
Port-A-Cool Cyclone and Jetstream Portable Evaporative Cooling Units Owner's Manual
Port-A-Cool Portable Evaporative Cooling Units, All Electric Models Owner's Manual
Portacool Cyclone Manual del propietario
Port-A-Cool — Manual do Utilizador para Unidades Eléctricas de Arrefecimento Evaporativo
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 82
All Time: 2,642
