Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
This page gathers troubleshooting resources for Candy induction cooktops (including the CI, CIS, and CIES series). Although the aesthetics vary by model, the internal layout generally relies on a standard frame integrating inductors (coils), a power module (electronic board), and a touch user interface.
Device Identification The exact model number and rated power are indicated on the rating plate affixed to the underside of the metal frame. It is crucial to note this information before ordering any spare parts.
Common Failures and Troubleshooting The most frequent repairs on these models concern:
  • Power board replacement: Often necessary following a short circuit or power surge (frequently associated with error code E8).
  • Ventilation fault: Clogging of the cooling fan causing a thermal safety shutdown.
  • Touch key malfunction: Connection issue with the control board or sensitivity defect in the glass-ceramic cooktop.
Important Safety Instructions CAUTION: Any intervention on an induction cooktop requires total disconnection from the power supply (dedicated circuit breaker). Wait at least 10 minutes after powering off to allow the board's capacitors to discharge to avoid any risk of electrocution.
Maxime
3,421 Reputation
5 Guides authored
Francophones Member of Francophones
Community
59 Members
336 Guides authored
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 155
All Time: 760
