Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
The mid-1970s (roughly 1977) saw the birth of Solid State machines. Instead of thousands of feet of wire and hundreds of mechanical switches, machines began using Integrated Circuits (ICs) and Microprocessors.
  • The MPU (Microprocessor Unit): Early 80s legends like Williams and Bally used the Motorola 6800 or 6808 8-bit processors. These "brains" allowed for complex logic, such as remembering a player's score after a "tilt" or carrying over bonuses between balls—something nearly impossible for mechanical machines.
  • Digital Displays: The 70s ended the era of spinning "score reels." They were replaced by Gas Discharge (Nixie-style) or Vacuum Fluorescent Displays (VFD). These orange-glowing digits were a revelation, as they didn't have moving parts that could jam or wear out.
The 1980s Sound Revolution
The early 80s brought "speech" to the arcade. Machines like Williams' Gorgar (1979) were the first to talk, using a very limited vocabulary synthesized by dedicated sound chips.
  • Dedicated Sound Boards: By the mid-80s, machines had separate audio boards (like the Yamaha YM2151 FM synthesis chip) that could play full musical scores and high-fidelity sound effects, a massive jump from the simple "chimes" and "beeps" of the 70s.
  • Speech Synthesis: This era utilized ADPCM (Adaptive Differential Pulse Code Modulation) to compress human voices into the tiny amounts of ROM available (often only 32KB to 128KB of memory).
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 100
All Time: 385
