Up to 20% off select tools
Documents
Please see the attached document for the service manual regarding this product.
Installation: page 2
Troubleshooting: page 16
Preventative Maintenance: page 24
Background and Identification
The Invacare Perfecto 2 is an oxygen concentrator designed for at-home use by Invacare. Invacare Corporation is an American producer of medical equipment like walkers, respiratory products, and wheelchairs. An oxygen concentrator is a medical or industrial device that concentrates the oxygen from either ambient air or another gas supply. Oxygen concentrators selectively remove nitrogen and other gases from the air to provide an oxygen-enriched stream.
The Invacare Perfecto 2 oxygen concentrator can produce a flow rate between one-half and five liters per minute. The Pediatric Flowmeter Accessory should be used for flow rates less than one liter per minute. It delivers air with oxygen purity between 95.6 and 87 percent at all flow rates. The concentrator is able to detect conditions that may indicate a potential obstruction, resulting in a reduction of output oxygen. The machine will emit a rapid audible beeping alert when the oxygen output is between zero and one-half liters per minute.
The Invacare Perfecto 2 oxygen concentrator can be used with a seven-foot cannula and a maximum of 50 feet of crush-proof tubing. This model is typically contained in white or grey plastic housing. The machines include four caster wheels for maneuverability. A built-in handle is located at the top of the oxygen concentrator.
Technical Specifications
Dimensions: 23" H x 13" W x 12" D
Product Weight: 40 lb.
Shipping Product Weight: 45 lb.
Oxygen:
  • Oxygen Flow: 5 LPM
  • Flow Range: 0.5-5 LPM
  • Oxygen Purity: 95.6%-87% At all flow rates
Sound Level: 43 dBA
Warranty: Limited Warranty - 3 Year
Additional Information
Wikipedia: Oxygen Concentrator
Wikipedia: Invacare
Invacare Perfecto 2 Product Catalog
Invacare Perfecto 2 User Manual
Perfecto2 Series HomeFill-Compatible Oxygen Concentrator Service Manual
Perfecto2 HomeFill-Compatible Oxygen Concentrator Sensored and Non-Sensored Service Manual
2009 Invacare Concentrator Repair and HomeFill Set-up Technical Education Seminar
Invacare Perfecto2 Series Oxygen Concentrators with and without SensO2 User Manual
Invacare Perfecto2 Series HomeFill-Compatible Oxygen Concentrators with and without SensO2 Operator's Manual
Invacare Perfecto2 IRC5P HomeFill-Compatible Oxygen Concentrators With/Without SensO2 Operator's Manual
Invacare HomeFill Ready Rack for Perfecto2 Concentrator Assembly, Installation and Operating Instructions
Invacare Perfecto2 Series Oxygen Concentrators (with/without SensO2) Operator's Manual
Invacare Perfecto2 Sensored and Non-Sensored Oxygen Concentrator Service Manual
Invacare Perfecto2 HomeFill Compatible Sensored Oxygen Concentrator Service Manual
Invacare Perfecto2 Series HomeFill-Compatible Oxygen Concentrator User Manual
Invacare Perfecto2 Series HomeFill Compatible Oxygen Concentrators User Manual
Invacare Perfecto2 Series Oxygen Concentrators with/without SensO2 — Operator's Manual
Invacare Perfecto₂ Series Oxygen Concentrators with SensO₂, HomeFill Compatible User Manual (EN, FR, IT, DE, PL, CS)
Invacare Perfecto2 Oxygen Concentrators with/without SensO2, HomeFill Compatible User Manual
Invacare Perfecto2 Series Oxygen Concentrators with/without SensO2 — Operator's Manual (EN, FR, IT, DE, PL, CS)
Perfecto2 Series Oxygen Concentrators with and without SensO2 — User Manual
Invacare Perfecto2 Oxygen Concentrators with/without SensO2, HomeFill-Compatible User Manual
5-Liter and 10-Liter Oxygen Concentrator Unit Details
Author
with
Eduardo Ortega
99 Reputation
0 Guides authored
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 58
All Time: 3,350
