6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
PA7PROR
Background and Identification
The Pearl Abrasive model PA-7PROR is a small tile saw made by the Pearl Abrasive Company. The saw is meant for wet cutting and includes a rear-positioned water feed to cool the cutting clade and control dust. Depending on the blade in use, the PA-7PROR saw can be used to cut ceramic tile, extra hard ceramic, porcelain, marble, granite, hardstone, and mosaic metal tiles.
The PA-7PROR model includes a 1-horsepower electric motor that operates at 6,000 revolutions per minute. The saw runs on 115 Volts at a frequency of 60 Hertz. It can cut up to 1.7 inches deep and 20 inches long for a rip cut, or 14 inches long for a diagonal cut. The saw weighs 42 pounds. The PA-7PROR’s frame is made of steel and it includes cast aluminum components. The saw also features a stainless steel water tray that provides control of water run-off. It includes a rubber mat that is bonded to the aluminum table for increased durability. Pearl Abrasive recommends using a 15 Amp circuit to operate this saw to prevent loss of power or interruption.
The PA-7PROR model can be identified by the name “Pearl” in white capital letters on the saw’s blade guard. It also includes the model name “PA-7PROR” on the blade guard in orange and grey letters.
Technical Specifications
Motor:
  • Power: 1 HP
  • Volts: 115 V
  • Frequency: 60 Hertz
  • RPM: 6,000
Maximum Blade Capacity:
  • 7” blade
  • 5/8” arbor blade
Cutting Depth: 1.7”
Weight: 42 lbs.
Dimensions: 33" L x 19" W x 13" H
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 72
All Time: 9,061
