Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Panasonic SA-PM17 is a 84dB/W, 2-way speaker stereo that features a 5-disc CD changer, audio cassette tray, AM/FM radio, and a remote control.
The product was originally released in 2002 and is one of several different SA-PM models that have been released both before and after it. Since its release, Sony has discontinued production of the stereo in pursuit of home theater packages and "MP3 Docking Solutions" such as the SC-HC series.
Identification
The stereo can be distinguished from other Panasonic models by its combination of a brushed steel finish and an extra LED screen on the CD tray cover. You can identify your stereo by the model number printed towards the top of the unit just below the Panasonic logo. The model and serial numbers can usually be found printed on the back of the device. The Panasonic site has helpful tips if you have difficulty finding this information.
Technical Specifications
General:
Power Supply: AC 120V, 60Hz
Power Consumption: 85W
Standby: Approx 0.5W
Dimensions (WxHxD):
179 x 241 x 375 mm
7 1/16 x 9 1/2 x 14 3/4 in
Mass: 5.6kg(12.3 lb.)
Amplifier:
Power Output:
10% Total harmonic distortion
60 Hz-3kHz, both channels driven (Low - 15W per channel)
3kHz-16kHz, both channels driven (High - 20W per channel)
Total Bi-Amp Power - 35W per channel
Input Sensitivity:
AUX: 250mV
Input Impedance:
AUX: 11.8 kOhms
AM/FM Tuner:
FM Tuner Frequency Range: 87.9 - 107.9MHz
AM Tuner Frequency Range: 520 - 1710kHz
Cassette Deck:
Track System: 4 track, 2 channel
Motor: DC Servo Motor
Tape Speed: 4.8 cm/s
Additional Information
Panasonic SA-PM17 on Amazon
Panasonic Help Videos
Panasonic SA-PM17 User Manual on Archive.org
Panasonic SC-PM27/SC-PM17 CD Stereo System Operating Instructions
Panasonic SC-PM17 CD Stereo System 120 V, 60 Hz — Manual de Serviço
Author
with
Robert Peters
1 Reputation
0 Guides authored
Cal Poly, Team 4-1, Regan Spring 2011 Member of Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 Members
60 Guides authored
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 130
All Time: 28,854
