Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background Information
The Lumix GH3 was the third iteration of the video oriented GH-series camera from Panasonic. The GH3 offered improvements over the GH2 such as higher bit rates, a magnesium shell, integrated Wi-Fi, better ISO performance and a higher detail viewfinder.
Technical Specifications
Camera Type: Mirrorless
Camera Mount: Micro Four Thirds
Sensor: 16 megapixels
Sensor Type: CMOS (17.3 x 13 mm)
Max Resolution: 4608 x 3456
Aspect Ratio: 1:1, 4:3, 3:2, 16:9
ISO Range: 200-25600
Max Shutter Speed: 1/4000 sec
Weight: 550 grams (1.21lb) [including batteries]
Dimensions: 133 x 93 x 82 mm (5.24 x 3.66 x 3.23″)
Storage Types SD/SDHC/SDXC
Resolutions 1080p (60, 50, 30, 25 24 fps) 720p (60, 50, 30, 25fps)
Viewfinder Resolution: 1,744,000 dots
LCD Resolution: 614,000 dots
Power Source: DMW-BLF19 7.2v 1860mAh Lithium-ion Battery
Additional Information
Anthony Kouttron
5,764 Reputation
5 Guides authored
salvagedcircuitry Member of salvagedcircuitry
Business
1 Member
60 Guides authored
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 84
All Time: 5,175
