Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Logitech Pro X3 Lightspeed is a wireless gaming headset with 50 mm Pro-G Graphene drivers, a detachable boom microphone, and audio customization through G HUB. It supports Lightspeed wireless and Bluetooth. Its microphone records at 48 kHz, and G HUB provides a 10-band parametric equalizer.
Identification
The Pro X3 Lightspeed is offered in Black with rotating memory foam ear cups and a detachable, articulated boom microphone. Available ear cushions include leatherette and velour. These shared design features should be checked alongside the product name before selecting generation-specific parts.
Technical Specifications
Audio:
  • Drivers: 50 mm Pro-G Graphene
  • Microphone: Detachable omnidirectional boom; 48 kHz sampling
  • Equalizer: 10-band parametric EQ through G HUB
  • Headphone frequency response: 20 Hz to 20 kHz
  • Driver impedance: 38 ohms
  • Microphone frequency response: 75 Hz to 20 kHz
  • Microphone capsule: 6 mm electret condenser, omnidirectional
  • Headphone sensitivity: 87.8 dB at 1 mW / 1 cm
Connections and Power:
  • Wireless: Lightspeed and Bluetooth
  • Rated battery life: Up to 70 hours; varies with use and computing conditions
  • Connections: Lightspeed, Bluetooth 5.3, and 3.5 mm analog audio
  • Wireless range: Up to 30 m; varies with the operating environment and setup
  • Charging port: USB-C
  • Battery: Rechargeable lithium polymer, 1100 mAh, 3.7 V
  • USB power: 5 V; charging current up to 0.5 A
Dimensions and Weight:
  • Dimensions (H × W × D): 176 × 189 × 95 mm
  • Weight: 356 g worldwide; 362 g for EMEA
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 70
All Time: 105
