Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Oxo 5lb Digital Kitchen Scale is designed to add both convenience and accuracy to the kitchen. The Oxo 5lb Digital Kitchen Scale sells for $29.99 on Amazon (as of 2020). The scale allows users to weigh various ingredients. It also includes features for added convenience. First of all, the display and control panel part of the scale pulls away from the scale base, allowing the display to be easily viewed even when there is a large object on the scale. The Oxo 5lb Digital Kitchen Scale also includes large numbers for easy reading, measurements in both imperial and metric, and a zero function so the scale can be cleared before taking measurements.
The Oxo 5lb Digital Kitchen Scale was also designed with portability and efficiency in mind. The scale is thin and small, meaning it can be easily and quickly tucked away when not in use. The Oxo 5lb Digital Kitchen Scale runs on two AAA batteries that are easy to remove and replace when the time comes. This means users won’t be fumbling around trying to complete a battery replacement when they should be measuring out ingredients in the kitchen.
The Oxo 5lb Digital Kitchen Scale includes controls and a display screen integrated into the scale base. The scale comes in both black and white.
Specifications
  • Dimensions: 7.9 x 5.65 x 1.1 inches
  • Weight: 1.35 pounds
  • Batteries: 2 AAA batteries
  • Capacity: 5 pounds
Additional Information
Author
with
Kael Lumen
236 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 61
All Time: 7,231
