Thermal Cutoff Fuse
2 Answers 3 Score |
How to replace a blown resistor and added conundrums? |
1 Answer 0 Score |
Noises when heating up? |
2 Answers 1 Score |
Why is not working |
2 Answers 0 Score |
The water does not heat up |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Oster model BVST-EK5967 is a digital electric kettle produced under the Oster brand. Sunbeam Products has produced a range of electric home appliances since 1910. The John Oster Manufacturing Company was purchased in 1960 by Sunbeam Corporation. Electric kettles are used to boil water without the use of a stovetop.
The Oster model BVST-EK5967 features a 1.7-liter capacity and 11 pre-programmed temperature settings with a back-lit digital display. This model can heat liquids to temperatures between 110 and 212 degrees Fahrenheit. The kettle has an automatic-shutoff that provides boil-dry protection. The electric kettle draws 1500 Watts of power. The Oster model BVST-EK5967 is powered by an electrical cord that can be plugged into standard electrical outlets. It features a 360-degree swivel base with a hinged locking lid to prevent boiling over.
The main components consist of a base, the heating ring, a breadboard, a handle, a lid contraption, and the control panel/LCD.
The device was released in 2013 and is currently available for purchase from the manufacturer, Jarden Consumer Solutions, or Oster, the company, in China. The main market targets are individuals all over the world who like to drink hot beverages. It retails for $19.99. In the current market, Oster has come out with significant model upgrades in the Metropolitan collection which include color changes, tighter degree controls, and an aesthetic overhaul to match modern minimalistic trends.
Identification
The Oster model BVST-EK5967 includes the name “Oster” printed in white letters on a black oval. The kettle is mainly stainless steel in color but has a black base, handle, and lid. This model includes a power light that alerts the user when it is heating. A water-level window allows the user to see how much liquid is in the kettle.
This device is easily identifiable by the bottom of the stand which indicates the exact model number, company, basic specifications, and warning labels. Additionally, the brushed steel exterior and wide but tall bodyline is unique of most modern tea kettles that are either short and stout or contemporarily tall and clear.
Technical Specifications
Weight: 3 lbs
Capacity: 1.7 liters
Power rating: 1500 watts and 100 to 250 volts
Dimensions: 6.9 x 8.9 x 9.5 inches
Source: https://www.amazon.com/BVST-EK5967-NP-Di...
