Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background
The OPPO A3 Pro 5G is an A-series Android smartphone. OPPO lists CPH2639 as the A3 Pro 5G model code in several regions, while the same model code is also associated with OPPO A80 5G in some markets.
OPPO lists the A3 Pro 5G with a 6.67-inch 120 Hz display, 5G connectivity, a 5100 mAh battery, 45 W SUPERVOOC charging, and a damage-resistant body design.
Identification
Identify the OPPO A3 Pro 5G by checking the model number in Settings > About phone, on the original packaging, or on the regulatory label. This page covers model CPH2639, including markets where CPH2639 is sold as OPPO A80 5G.
The OPPO A3 Pro 5G has a centered hole-punch display, two rear camera rings, USB-C, and a side-mounted fingerprint sensor.
Technical Specifications
  • Display: 6.67-inch HD+ display, up to 120 Hz
  • Rear cameras: dual rear camera system led by a 50 MP camera, depending on market
  • Battery: 5100 mAh typical
  • Charging/data port: USB-C
  • Charging: 45 W SUPERVOOC support
  • Connectivity: 5G and 4G LTE
  • Operating system: ColorOS based on Android
Additional Information
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 9
Past 7 Days: 46
Past 30 Days: 152
All Time: 751
