Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Nonin Avant 2120 is a pulse oximeter manufactured by Nonin Medical. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. Nonin Medical designs and manufactures pulse oximeters, regional oximeters, and capnographs for patient monitoring.
The Nonin Avant 2120 is a portable pulse oximeter used to measure, display, and record the patient’s pulse rate, blood pressure, and functional oxygen saturation of arterial hemoglobin. This model can be used for spot-checking or continuous monitoring of patients. It is suitable for use with adult, pediatric, and neonatal patients. The Avant 2120 model can be used in hospitals, medical facilities, and subacute environments.
The Avant 2120’s blood pressure monitor is designed to non-invasively monitor the blood pressure of adult and pediatric patients. The blood pressure monitor is not designed to be used for neonatal patients. It is intended to be used for patients with arm circumferences between 18 and 42 centimeters.
Numeric light-emitting diodes (LEDs) in the upper left-hand corner of the 2120 model’s front face display the patient’s blood oxygen saturation as a percentage. The patient’s pulse rate is displayed in the lower numeric display in the device’s upper left-hand corner.
The Nonin Avant 2120 includes the name “NOVIN” printed in capital letters in the bottom center of the device’s front face. The model number, “2120,” is printed underneath the Novin name.
Technical Specifications
Oxygen Saturation Display Range: 0 to 100% SpO2
Pulse Rate Display Range: 18 to 300 beats per minute (BPM)
Displays:
  • Numeric Displays: 3-digit LEDs, Tricolor (red, green, amber)
  • Pulse Indicator: Amber LED
Accuracy – Sensors: Declared accuracy data for compatible sensors can be found in Nonin’s Sensor Accuracy document.
Measurement Wavelengths and Output Power:
  • Red: 660 nanometers @ 0.8 mW max. average
  • Infrared: 910 nanometers @ 1.2 mW max. average
Method of Measurement: Oscillometric
Blood Pressure Range:
  • Systolic: 40 mmHg to 260 mmHg
  • Diastolic: 25 mmHg to 200 mmHg
  • MAP = 1/3 Systolic + 2/3 Diastolic
Pressure Transducer Accuracy: ±3 mmHg between 0 mmHg and 300 mmHg for operating conditions between 0 °C and 50 °C. (S.D. of 8 mmHg)
Recommended Frequency of Pressure Transducer Calibration:
The Pressure Transducer calibration should be verified yearly or every 10,000 readings, whichever comes first.
Pulse Rate Range: Up to 200 pulses per minute (BPM) [displayed if there is no value from the oximeter]
Blood Pressure Altitude: -170 to 12,000 m
Temperature:
  • Operating: 32 °F to 122 °F (0 °C to 50 °C)
  • Storage/Transportation: -40 °F to 158 °F (-40 °C to 70 °C)
Humidity:
  • Operating: 10% to 90% noncondensing
  • Storage/Transportation: 10% to 95% noncondensing
Power Requirements:
  • Mains: 100-240 VAC 50-60 Hz
  • DC Input: 12 VDC 1.5A AC power supply
Internal Power:
  • Battery: 7.2 volt battery pack (6 cells)
  • Operating Life: minimum 5 hours of continuous operation
  • Storage Life: 18 days
  • Recharge Time: 4 hours with device off
Memory: 33.5 hrs (assuming continuous operation)
Alarm Volume Range: 55–81 dBA
Informational Tone Volume Range: 50–70 dBA
Altitude:
  • Operating: Up to 40,000 feet (12,192 m)
  • Hyperbaric Pressure: Up to 4 atmospheres
Dimensions: 4.5 x 7.5 x 5.4 in. (11.4 x 19.0 x 13.8 cm)
Weight: 45.3 oz. (1.28 kG) with batteries
Mode of Operation: Continuous
Additional Information
Nonin Avant 2120 Support Page
Nonin Avant 2120 Operator’s Manual
Nonin Avant 2120 Product Page
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 39
All Time: 519
