Up to 20% off select tools
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
Released in 2009, the Nokia X3 is the first mobile handset released by Nokia that possesses a touchscreen in a "candybar" phone form factor. It is also the first touchscreen handset from Nokia that runs the Series 40 Operating System. Previously released touchscreen devices from Nokia have either not had a physical keyboard, or they have had a slide-out, full-QWERTY keyboard.
There is also hardware upgrade version available of this phone, which can be identified from RM-775 and X3-02.5 codes in the sticker which can be found under the battery. The X3-02.5 (RM-775) differences compared to X3-02 (RM-639) are: 1Ghz CPU vs 680 MHz CPU, 256 MB ROM vs 128 MB ROM and 128 MB RAM vs 64 MB RAM.
Specifications
Memory
  • MicroSD slot (supports up to 16 GB)
Display
  • Resolution: 240 x 320 pixels (182 ppi)
  • Panel: 2.2 inch 4:3 TFT LCD
Camera
  • Resolution: 3.2 MP
Battery
  • Capacity: 860 mAh user-replaceable lithium-ion
Design
  • Dimensions: 3.78 x 1.94 x 0.56 inches
  • Weight: 3.63 oz.
Connectivity
  • Micro-USB
  • 3.5 mm headphone jack
  • Bluetooth 2.1, EDR, A2DP
  • Stereo Radio
  • 2G GSM
Additional Information
User Guide
Nokia X3-02 用戶指南
X3-02 User Guide
Nokia X3-02 User Guide
Nokia X3-02 — Manuel d'utilisation, Édition 3.0
Nokia X3-02 Bedienungsanleitung
Nokia X3-02 Manual do Utilizador
X3-02 Manual do Usuário
Nokia X3-02 — руководство по эксплуатации
Author
with
Matteo Moro
536 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 76
All Time: 6,931
