Up to 20% off select tools
Student In Progress
This wiki is being worked on by hardworking students.
Troubleshooting
For more information regarding common troubleshooting issues, please refer to these troubleshooting pages:
Nokia 8 Screen Won't Turn On
Nokia 8 Battery Won't Charge
Background
Like the Nokia 3, Nokia 5 and Nokia 6, it ran a near-stock version of Android 7.1.1 "Nougat" on release. One difference is the camera mobile app, so as to cater to the phone's Dual-Sight feature. It also comes with an always-on display, similar to Nokia's previous Glance Screen on the Nokia Lumia series. Announced on 16 August 2017 in London, England, it was developed in Espoo, Finland, by HMD Global. By late 2018, HMD Global announced that they had sold 70 million Nokia-branded phones.
The Nokia 8 was officially discontinued on January 1, 2022. This particular device was not designed to be exclusive to any particular country or region of the world. They explicitly designed and marketed this phone for millennial content creators, influencers, and story tellers. The Nokia 8 originally launched at a retail price of around $550 dollars. This device was able to make headlines for being the first true high-end Android flagship to endure the the legendary Nokia Brand name. And, the feature that dominated launch news was "dual-sight" mode.
There are no official manufacturer recalls for the Nokia 8. Although the Nokia 8 is praised for its durability, there are several components have a documented history of failure or malfunction. For example the USB-C charging port along with the Display Assembly & Screen Flex Cable. Users frequently praise the clean software experience, along with smooth and free of lag usage. There are also some mixed concerns about long-term hardware use causing progressive screen malfunction along with no physical grip on the back of the phone leading to easy phone slippage.
Within the linage of Nokia versions, the Nokia 8 served as the foundational model, of course being the first high-end Android flagship smartphone following Nokia's transition away from the Windows Phone. This device in particular did not directly replace an immediate Android predecessor, however, the Nokia 8 by itself was succeeded and refined by the Nokia 8 Sirocco. The Nokia 8 features an aluminum unibody metal build with a 16:9 aspect ratio and larger / physical bezels around a front fingerprint scanner. The Nokia 8 Sirocco upgrades to a curved edge design with a stainless steel frame, Gorilla Glass 5 on the front and back, a rear-mounted fingerprint sensor, and smaller bezels yielding an 81% screen-to-body ratio.
Identification
Nokia 8 comes with the Qualcomm Snapdragon 835 CPU, backed by either 4 or 6 GB of RAM and 64 GB of internal storage (Tempered Blue, Steel and Polished Copper-colored models), or 6 GB of RAM and 128 GB of internal storage (Polished Blue). Both are expandable with microSD cards. The QHD display is protected by Gorilla Glass 5. The device includes the USB-C 3.1 Gen 1 port for charging and data transfer (up to 5 Gbit/s).
The Nokia 8 has a 5.3" display and averages 7.3 mm thick and 4.3 mm thick at the edges. It is available in four colors: Polished Blue, Polished Copper, Tempered Blue and Steel. The device features a full-length graphite-shielded copper cooling pipe that is designed to pull the heat away from the Snapdragon 835 chip and dissipate it across the full length and breadth of the smartphone. The phone is not water-resistant but is IP54 splash-resistant.
Technical Specifications
Nokia 8 is the first Nokia-branded phone to feature a dual-lens camera system. The rear camera module includes a set of two 13 MP sensors, of which one is an RGB sensor, and the other a monochrome sensor. The rear camera is equipped with optical image stabilization (OIS), f/2.0 aperture, PDAF, an IR rangefinder, and a dual-LED flash.
The front and rear cameras' combined standout feature is an advanced dual photographic image camera (rebranded "Bothie" by Nokia), where the cameras can be used simultaneously by dividing the screen into a split-image setup, a technology Nokia calls Dual-Sight mode. Both the front and main cameras use ZEISS optics.
Video recording can be done in resolutions of 2160p at 30fps (4K) and 1080p at 30fps (FHD), with single-touch live streaming to social networks. The cellphone contains several microphones able to record spatial audio 360° with binaural audio codecs, providing high fidelity playback through OZO Audio technology, which was derived from the Nokia OZO camera. The phone is equipped with a single rear-mounted loudspeaker, so is not fully Dolby Atmos compatible.
It is equipped with a 3.5 mm headphone jack and Bluetooth. These audio outputs use the OZO spatial audio playback to produce high quality 360° surround sound from two speakers(or earbuds) and use decoding standards compatible with Dolby Atmos and other earlier surround sound standards.
Additional Information
Wikipedia: Nokia 8
Nokia 8 Teardown - Screen Repair and Battery Replacement
Nokia 8 User Guide
Nokia 8 Battery Replacement Guide
Nokia 8 Screen Replacement Guide
Nokia 8 Camera Replacement Guide
Nokia 8 Motherboard Replacement Guide
Nokia 8 Headphone Jack Replacement Guide
Author
with
Alex Niculescu
17,633 Reputation
0 Guides authored
Cooperators Member of Cooperators
Community
20 Members
408 Guides authored
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 126
All Time: 21,221
