Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Nidek Medical Mark 5 Plus is an oxygen concentrator developed by Nidek Medical. Nidek Medical is a medical device and oxygen concentrator producer. An oxygen concentrator is a medical or industrial device that concentrates the oxygen from either ambient air or another gas supply. Oxygen concentrators selectively remove nitrogen and other gases from the air to provide an oxygen-enriched stream.
The Nidek Medical Mark 5 Plus oxygen concentrator produces air that is 90 percent oxygen when operating at a rate of five liters per minute. An Oxygen Monitoring System is available for monitoring the oxygen purity of the output air. The machine has an average power consumption of 420 Watts.
The Mark 5 Plus includes two test ports that monitor the system’s pressure at two points. Users can compare the pressure ranges measured at these points with the System Diagnosis Charts found on page 9 of the Nidek Medical Mark 5 Plus User Manual. Use the Troubleshooting Guide on page 10 of the User Manual to determine the probable cause of problems and repair them.
The Nidek Medical Mark 5 Plus oxygen concentrator is typically contained in white or grey plastic housing. The machines include four caster wheels for maneuverability. Users can attach an optional humidifier into a slot at the front of the machine.
Technical Specifications
Height: 26 in / 660 mm
Width:15 in / 380 mm
Depth: 15 in / 380 mm
Weight: 60 lbs / 27 kg
Output: 90% +/- 3% @ 5 LPM
Voltage: 115 V; 60 Hz
Average Power Consumption: 420W @ 60 Hz
Cooling Air Temperature Rise: Less than 30°F / 16°C
Additional Information
Nidek Medical Mark 5 Plus Service Manual
Nidek Medical Mark 5 Plus Review, Features, and Benefits
Nidek Mark 5 Plus Oxygen Concentrator User Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 519
