Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Nellcor N-600x with Alarm Management System is a pulse oximeter made by Mallinckrodt’s Nellcor division. It is also called the OxiMax N-600x with Alarm Management System. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. The Nellcor division focuses mainly on producing pulse oximeters and oxygen monitors. The Nellcor N-600x with Alarm Management System is identical to the Nellcor N-600x pulse oximeter but includes an OxiMax Technology Alarm Management System.
The OxiMax N-600x with Alarm Management System is designed to continuously monitor the patient’s pulse rate and the functional oxygen saturation of arterial hemoglobin. It is suitable for use with adult, pediatric, and neonatal patients in hospitals, intra-hospital transport, hospital-type facilities, and home environments.
The OxiMax SPD Alert feature is designed to detect patterns of desaturation that indicate repetitive airflow reduction through the patient’s upper airway and into the lungs. The N-600x model with Alarm Management System is compatible with a range of OxiMax pulse oximetry sensors.
This pulse oximeter includes the name “NELLCOR” printed in capital letters in the upper left-hand corner of the device’s front face. The model name, “OxiMax N-600x,” is printed in the upper right-hand corner of the monitor’s front face.
For preventative maintenance, troubleshooting, and repair information, see the Nellcor N-600x with Alarm Management System Service Manual.
Technical Specifications
PERFORMANCE
  • MEASUREMENT RANGE:
    • SpO2 : 1% to 100%
    • Pulse rate: 20 to 250 beats per minute (bpm)
    • Perfusion range: 0.03% to 20%
ACCURACY:
  • Saturation (% SpO2 ± 1 SD):
  • 70% to 100% ± 2 digits
  • 60% to 80% ± 3 digits
  • Low perfusion: 70% to 100% ± 2 digits
  • Pulse rate: 20 to 250 bpm ± 3 digits
  • Low perfusion: 20 to 250 bpm ± 3 digits
ELECTRICAL:
* INSTRUMENT:
  • Power requirements: 100 to 120 VAC, 200 to 240 VAC, 50/60 Hz, 20 VA
    • Fuse rating: 0.5 Amperes
  • BATTERY:
    • Type: Sealed lead-acid internal battery
    • Battery capacity: Typically 7 hours using new, fully charged battery
    • Charge time: 8-12 hours
ENVIRONMENTAL:
  • OPERATING TEMPERATURE:
** Instrument: 5°C to 40°C
  • Transport/storage temperature (in shipping carton): -20°C to 70°C
    • Operating humidity: 15% to 95% noncondensing
    • Operating altitude: -1,280 ft to 12,000 ft
PHYSICAL CHARACTERISTICS:
  • Weight: 5.7 lb (2.6 kg)
  • Size: 3.3 in H x 10.4 in W x 6.8 in D (8.4 cm x 26.4 cm x 17.3 cm)
EQUIPMENT CLASSIFICATION:
  • IEC 60601-1
  • ISO 9919
  • CSA 601.1
  • EN/IEC 60601-1-2 (2nd ed.)
  • UL 2601-1
  • IPX1
  • EN865
EMISSIONS COMPLIANCE:
  • EN55011, Group 1, Class B
OUTPUT:
  • EIA-232 and RS-422 digital output from serial port
  • OxiNet Communications Output Protocol
  • Nurse call capability
  • Analog output (0-1V); SpO2 , pulse rate and plethysmographic waveform
DISPLAYS/INDICATORS:
  • High-quality LCD graphical screen
  • Visual indicators: Pulse search, audible alarms silenced or off, interference indicator, low battery and battery charging, battery fuel gauge, sensor off, sensor disconnect, data in sensor and SatSeconds alarm management clock
ALARMS:
  • Audible and visual alarms for high/low saturation and pulse rate
  • SatSeconds alarm management settings: 10, 25, 50, 100 or OFF
  • Audible and visual warning indicators for low battery
  • Audible sensor disconnect alarm and sensor off alarm
  • Displayed saturation and pulse rate alarm limits
  • Backup speaker with escalating alarm tones
OPTIONAL ACCESSORIES:
  • GCX mounting options
  • Interface cables
  • Carrying cases
Additional Information
Nellcor N-600x with Alarm Management System Upgrade and Activation Procedure
Nellcor N-600x with Alarm Management System Product Page
Nellcor N-600x with Alarm Management System Brochure
Nellcor OxiMax N-600x Pulsoximeter Gebrauchsanweisung
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 393
