Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background Information
Introduced to the public in October of 2006, the Motorola WT4000 was a wearable mobile computer that was designed to be worn by the user, either by being mounted to the wrist or hip, along with an optional scanner that is mounted to the user’s fingers or back of hand.
While the WT4000 was designed primarily to be used for data capture and inventory management, the WT4000 features an IP54 seal to protect from dust and water, can survive multiple drops of 4 ft to concrete, and can operate in temperatures as low as -4 °F.
The production of the WT4000 ended in 2013 and was suceeded by the WT6300.
Technical Specifications
General Information
  • Color Options: Grey
  • Keyboard: 23-key alphanumeric w/ legacy alpha entry or cell phone-like alpha entry.
  • Form-Factor: Wearable Computer
  • Production Years: 2006 - 2013
Physical Dimensions
  • Weight: 11.3 oz (320.3 g) w/ battery
  • Length: 5.7 in (142 mm)
  • Width: 3.7 in (93 mm)
  • Height: 1 in (26 mm)
Power
  • Battery Type: Li-Ion
  • Amp Hours: 2,330 mAH or 4,600 mAH on extened
  • Voltage: 3.7 V
Operating System
  • OS: Windows CE 5.0 Professional
Chipset
  • Processor: 520 MHz Intel XScale PXA270
  • Memory Options:
    • 64 MB
    • 128 MB
    • 128 MB Flash ROM
Display
  • Screen Size: 2.8" TFT LCD
  • Resolution: 320 x 240 QVGA
Interface
  • USB
  • Bluetooth v1.2
  • 802.11 a/b/g
  • Microphone
  • Speaker
  • Hand mount/Ring Laser Scanner
Enviornmental Resistance
  • Operating Temprature: -4° to 122° F
  • Humidity: 5% to 95% non-condensing
  • Drop Resistance: 4 ft (1.22 m) to concrete
Features
  • USB Batch and 802.11a/b/g interfaces
  • 520 MHz Intel Xscale PXA270 Processor
  • Runs Windows CE 5.0 Pro
  • Bluetooth for VOIP communications and Voice-Based Picking
Additional Information
The Enterprise Mobility Product and Services Portfolio — At-a-Glance Chart
Motorola RS507 Corded/Cordless 1D/2D Hands-Free Imager Specification Sheet
Motorola Série WT4000 Terminal mains libres — Fiche technique
摩托罗拉 WT4000 系列佩戴式终端产品资料
Motorola RS507 Imager a mani libere 1D/2D con e senza fili — Scheda specifiche
Motorola Serie WT4000 Terminal Portátil — Hoja de especificaciones
Motorola Serie WT4000 Terminale portatile — Scheda specifiche
Motorola RS507 Hands-Free имидж-сканер, беспроводной или проводной — техническое описание
Motorola RS507 Imager manos libres, lectura 1D/2D con y sin cable — Hoja de especificaciones
Motorola RS507 Imageur mains libres câblé ou sans fil — Fiche technique
Motorola WT4000 Serisi Giyilebilir Terminal Özellik Sayfası
Motorola WT4000 Series Hands-Free Wearable System Application Brief
Motorola WT4000 シリーズ ウェアラブル ターミナル 仕様書
Motorola WT4000 系列穿戴型終端機產品簡介
Motorola Serie WT4000 Terminal portátil Hoja de especificaciones
Серия Motorola WT4000 — переносной терминал: брошюра
Motorola WT4000 sorozat hordható terminál — műszaki jellemzők adatlap
Motorola Serie WT4000: terminal portátil — hoja de especificaciones
Motorola Serie WT4000: terminal portátil de manos libres — hoja de especificaciones
Motorola серия WT4000: переносной терминал hands-free — технические характеристики
Motorola RS507 Imager manos libres con y sin cable 1D/2D — Hoja de especificaciones
Motorola RS507 Hands-Free Corded/Cordless 1D/2D Imager Specification Sheet
Motorola Serie WT4000 terminale a mani libere — Scheda specifiche
摩托罗拉 WT4000 系列免持式佩戴终端规格说明
Motorola Série WT4000 Terminal mains libres — fiche technique
Motorola Serie WT4000 Wearable Terminal — technische Daten
Motorola WT4000 系列穿戴型終端機規格表
Symbol WT4000 시리즈 착용식 단자 제품 사양서
Motorola WT4000 Serisi Giyilebilir Terminal — özellik sayfası
Motorola WT4000 Series Wearable Terminal Specifications
Motorola WT4000 シリーズ ウェアラブル ターミナル仕様書
Motorola Serie WT4000 Wearable Terminal — Technische Daten
Motorola WT4000 sorozat hordható terminál — műszaki adatlap
Motorola RS507 imageur mains libres 1D/2D câblé ou sans fil — fiche technique
Motorola RS507 Hands-Free — техническое описание проводного или беспроводного 1D/2D сканера
Motorola WT4070/90 Wearable Terminal Integrator Guide
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 50
All Time: 566
