Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
154650-HD-JCS
Background and Identification
The MK Diamond model MK-101 is a medium tile saw that can cut ceramic, porcelain, and stone tiles. The MK-101 is identical to the MK-101-24 but does not include an extended frame. The MK-101 allows users to cut tiles up to 20 inches in length and an integrated stand that allows the user to set up the saw or transport it. The MK-101 includes a 1.5-horsepower fan-cooled motor that operates at 3,450 revolutions per minute. It can accommodate between 6-inch, 8-inch, and 10-inch profile cutting wheels.
The MK-101 model features a multi-position motor post and cutting head that allows the operator to configure the saw for cutting both small and large tiles. The saw includes a built-in water distribution system that supplies water to both sides of the cutting blade. The water system decreases dust and debris and also cools the cutting blade for less wear. The saw’s blade shaft can lock for easier blade removal and replacement. It includes a chrome-plated guide bar and linear-bearing assembly to produce more precise cuts. The saw also includes a white plastic tub that catches used water when wet cutting.
The MK-101 model can be identified by the name “MK” printed in bolded letters with a diamond shape and the number “101” on the front of the saw’s main handle, on the blade guard, and on the white plastic tub used for retaining used coolant. The saw’s blade cover, handle arm, and motor cover are a red or orange color.
Technical Specifications
Voltage: 120V
Horsepower: 1-1/2 hp
Blade RPM: 3,450
Blade Capacity: 10" (254mm)
Arbor Size: 5/8" (16mm)
Depth of Cut: 3" (76mm)
Length of Cut: 20"
Diagonally Cuts: 14" Tile
Weight: 92 lbs. (42 kgs.)
LxWxH: 36" x 22" x 23"
LxWxH (mm): 914 x 559 x 584
Additional Information
MK Diamond MK-101 Home Depot Rental with JCS Stand Tile Saw Owner's Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 3,309
