Up to 20% off select tools
Documents
History and Diagnostics
General History
-Commercial retail box advertisement, 1988
We know Mitsubishi often for their cars, but they're also known to produce quite a lot more than that. pencil lead, forklifts, air conditioners, even naval ships and fighter planes during WWII. But very few people know about the Mitsubishi mp286L, which, while it isn't their first commercial computer(they first created the MSX home computers), it still stands as their first entry into the business laptop market.
Their entrance into the business was poorly timed however, as its release in 1988 was placed in the middle of the technological advancement to faster, tougher hard drives and RAM, alongside the advent of the more reliable medium of CDs. This, on top of the already stiff competition, left their hard drive manufacturers, Miniscribe, to engage in scandalous operations out of desperation to keep up with business. Naturally, it ended in their bankruptcy and their acquisition by Maxtor, and cut Mitsubishi's assembly lines short.
Before anyone knew it, production of these portables came to a stop, where they grew outdated in the coming of the 90's, and have fallen into heavy obscurity since.
Identification
Like all laptops of its era, it had a relatively small hard drive capacity, uses older means of communication like serial and parallel, a 3.5" floppy disk drive, and being relatively oversized and heavy to carry.
Everything is inside a dark gray, hard plastic casing with a sleek finish. The bulky clam-shell display is slightly curved at the top, while the bottom and the sides are mostly flat, forming a nearly box-like shape. All edges and corners are rounded. Coming off the front of the closed unit is a handle that clicks in and out.
Mitsubishi built these machines with no battery, in exchange for capability and portability. This means they only run entirely on AC power and have to be plugged into an outlet or power box in order for them to be used. This also means these machines are more like a portable desktop, rather than a true laptop.
They also used a very odd keyboard configuration. Both the function and arrow keys are half-sized horizontally, and rearranged so that the arrow keys are in the top right corner, and the last 4 function keys placed above the first 4, across to the right from the arrow keys. This makes it awkward to use the keyboard to it's fullest, since they can be easy to miss and somewhat hard to use.
Where is this going?
Due to the brief life of these computers in the market, alongside their strange form factors, it proved to be incredibly difficult to find any information on these lap crushers. So, for archival purposes, I took it upon myself to create this ifixit page dedicated to these machines, so that anything, and everything that can be found on these things can be placed here for all to see. Any and all useful additions are welcome!
Important Specs
General Info
*both distributed and manufactured by Mitsubishi Electric (Disks Monitors)
  • Brand: Mitsubishi
  • Series: MAXY portable (IBM compatible(see Software Things for details))
Model Numbers:
  • 210 (with dual floppy 3.5" drives)
  • 220 (1 floppy drive, 1 hard drive)
  • 240EVP (with an EGA screen)
  • MP-2120* (*I have this one, same as 220)
  • MP-2130
Weight: ~10-16 lb (4.5-7.2 kg)
Original Price Range: From 5400$
  • can range from 1400-5000$ by other retailers
Size: (W"xH"xD") 12.3" x 3.5" x 14.2"
Warranty: 1 year by Mitsubishi
What's Inside...
Processor: Intel 80286
  • Clock rates: 5, 6, 8/12 (standard), 16*, 20*, 25MHz* (*later models released by Fujitsu and AMD)
  • Processing power: 6-12MHz (1 wait state for anything above 8MHz)
    • works with an optional Intel 80287-8 math co-processor
Memory: 640 kb of RAM
  • expandable to 2.6 mb with proprietary memory card (more info to be found on it)
Power:
* Whole power supply unit:
  • Model No.: PC21WA (Power supply circuit type by model no. is TBD)
    • Voltage needed: 115V, 220V-*240V (*230V is the factory setting)
      • pair of switches on the back control preferred voltage
    • Power Cable: Standard IEC AC power cable within the above voltages
  • CMOS: Proprietary Varta Ni-Cd battery (Be sure to remove that)
    • Volts & Amps: 3.6v, 170mAh
Built-in Storage: Miniscribe Hard Drive* (*Check links in the references for pictures)
  • No. of drive types: 0-47 (this is shown and requested in the setup disk software)
  • Model No. : M8425* (*often shortened to just 8425)
    • interface: ST506
    • Recording methods: MFM, SCSI* (*uses a different controller card, likely 3rd party)
    • Capacity: 20-21MB
      • Can go up to 40MB+ in EVP models with NEC brand drives
    • Phase: DTF
    • Platter size: 3.5"
    • No. of Heads: 4
    • No. of Cylinders: 615
Internal Floppy drive: 3.5"
  • Disk capacities: 720 kb (standard), 1.44 mb (High Density)
    • It's one or the other when comparing purchasable units
Sound: 1x 15 mm x 2 mm Piezo speaker plate
What's outside...
I/O: all of these are connected to the main computer board by 4 proprietary card slots
  • Serial ports: 2x male-end 9-pins (RS-232C)
  • CRT Display out: 1x female-end 9-pin (likely serial communication)
    • Can connect to an external 16-color CRT display
  • Network Inputs: 1x line, 1x telephone jacks (Both shaped like RJ45, not RJ11)
    • works with an optional 2400 bps modem which can be installed inside the machine (They even give an installation guide!)
  • External drive: 1x 26-pin floppy drive* (*female port end)
    • connects with 5.25" 1.2mb or extra 3.5" 1.44mb floppy drive
    • Cable Pinout
  • External input device: Female bus port end (for number pad mentioned in Included Software section)
  • Printer Cable: 1x Centronics 25-pin parallel
  • Back-Switches*: 2x arrays of 4 switches (for small, temporary changes after set up)
    • DTS-4 to the left of FDD port (if looking from the back)
    • DPS-4 to the right of CRT port (if looking from the back)
      • 6 levers present by CRT on MP-2130 Model (why it's different is unknown)
Keyboard:
  • No. of keys: 86/101*
    • only w/ aforementioned number pad
  • Key layout: Custom AT
    • Letter keys: QWERTY, AZERTY
  • Design: Mechanical alps switches
Display:
  • Type: back-lit cold CRT, passive-matrix neutral 'supertwist' nematic LCD
    • Knobs and switch on bottom right corner of front bezel control back light and blacks-on-whites contrast configuration
  • Dimensions: (WxH) 9" x 6.5", 11" diagonal
  • Pixel Resolution: 640 x 200-400, for graphics and text respectively
  • Character resolution: 80 characters/line
  • compatible aspect ratios: EGA and CGA
    • Some documentation mentions a unique 'Hercules' resolution mode. More information on that soon...
Software Things
Included In-Box Software:
  • Setup & diagnostics (for any pre-POST configurations)
  • utilities (for mouse and/or number pad, as well as dial-up connection and system checkup)
  • MS-DOS 3.30 driver
  • WordPerfect (circa 1990, "For IBM Personal Computers")
    • Some units are found with a Cheat sheet for keyboard shortcuts (likely for office/school use)
  • GWBASIC 3.20-30 (BASIC programmer for MS-DOS)
  • Super PC-kwik (hard drive performance booster)
BIOS: Phoenix 80286/80386 ROM BIOS version 3.10 (IBM BIOS clone)
  • Fun Fact: This is the same BIOS type used in the iconic Compaq Portable Laptop
Below is a checklist of included in-box documentation
KEY:
[] (not accessible to me at all)
[-] (readily accessible but not scanned)
[/] (scanned and uploaded)
  • [-] MS-DOS 3.30 Quick Reference
  • [] MP 286L Quick Reference
  • [] MP 286L Internal 2400 BPS Modem Installation Guide (as mentioned before)
  • [] MP 286L User's Guide
  • [] MS-DOS 3.30 User's Guide
Once again, All helpful and useful additions are welcome! Thank you!
References & Additional Things
Sources:
BCBarlow's Teardown Guide (Archived blog post)
This Machine on The Center of Computing History
Google Books search on the MP 286L (Where I found most of the information here)
Pictures: Courtesy of Higher Intellect's Vintage Computing Wiki
Pictures of the laptop
Pictures of its fixed hard drive
Info and pictures on an Estonian web museum
Downloads:
Utilities software download
BIOS Setup and diagnostics download
Another setup download from a troubleshooting forum
-All downloads made possible by VOGONS Vintage Driver Library-
YouTube videos
Russian unboxing video of a used (but working) unit
MikeTech's repair and exploration of one from VCF (This Guy's cool! Go check his other stuff as well)
2010 haul w/ a unit plus an external 5.25 floppy drive (Video's very blurry, but you can make it out)
eBay listings:(*unavailable listings)
Laptop with number pad accessory and carrying case*
Laptop with included Manuals, discs, and carrying case*
Laptop with bonus power cord and all documentation*
User Guide, Quick ref, Modem installation Booklets
Forums & Threads:
Discussion about one on Silicium (French retro-gaming/computing forum)
On r/retrobattlestations:
Troubleshooting thread regarding system FDISK
Followup thread on a CHECK SUM FAILED issue (take your time reading these)
Rando_GUY
893 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 63
All Time: 2,019
