Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Mitsubishi Carisma Technical Specs
Engine and Performance
  • Gasoline Options:
    • 1.6L to 1.8L SOHC/DOHC: Producing between 90 and 115 hp.
    • 1.8L GDI (Gasoline Direct Injection): The flagship engine producing 122 to 125 hp.
  • Diesel Options:
    • 1.9L TD/DI-D: Sourced from Renault, producing 90 to 115 hp depending on the generation.
  • Acceleration 0-100km/h: Approximately 9.2 seconds for the 1.8L GDI manual.
Drivetrain and Transmission
  • Drive Type: Front-Wheel Drive (FWD).
  • Transmission Choices:
    • 5-speed manual: Known for a light, easy shift action.
    • 4-speed INVECS-II automatic: An "intelligent" adaptive transmission that learned the driver's style (available on 1.8L models).
  • Efficiency: The GDI engine was revolutionary for its time, capable of achieving roughly 45 mpg (UK) on the extra-urban cycle.
Chassis and Suspension
  • Platform: Shared "Global" platform with the Volvo S40/V40, though Mitsubishi used their own suspension tuning.
  • Front Suspension: MacPherson struts with a stabilizer bar.
  • Rear Suspension: Multi-link independent setup, which provided superior ride comfort and handling stability compared to the torsion beams found in many rivals.
  • Brakes: Ventilated discs (front) and drums or solid discs (rear) depending on the engine size.
Dimensions and Capacity
  • Body Styles: Available as a 4-door sedan or a more popular 5-door hatchback.
  • Length: 174.6 inches (4,435 mm).
  • Curb Weight: Approximately 2,400 to 2,800 lbs (1,080-1,270 kg).
  • Boot Space: Roughly 15.1 cubic feet (430 liters), which was quite competitive for its class.
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 166
All Time: 545
