No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Models
2680-20-
Background
The Milwaukee Die Grinder 2680-20 is a handheld power tool primarily used for grinding, sanding, and honing a material's surface. This die grinder is cordless and runs on 18V lithium-ion batteries. It's designed with an angled head and a rubber grip to provide precise control during use. The tool is equipped with a spindle lock, which allows for quick wheel changes.
The speed of the Milwaukee Die Grinder 2680-20 is not variable; it operates at a maximum speed of 9,000 RPM. The 4.5-inch wheel capacity makes it suitable for use with different types of wheels, depending on the intended application. This grinder is used for a variety of tasks, including weld grinding, rust removal, cutting, and sharpening. Despite its capabilities, the grinder is lightweight, weighing only 4.4 lbs without the battery, which helps reduce fatigue during extended use.
Technical Specifications
  • Model Number: 2680-20
  • Product Type: Die Grinder
  • Dimensions: 10 in (depth), 4.5 in (height), 12 in (width)
  • Wheel Diameter: 4.5 in
  • Arbor Size: 0.625 in
  • Battery: M18 lithium-ion (sold separately)
  • Voltage: 18V
  • Maximum RPM: 9,000
  • Motor Type: Brushed
  • Weight: 4.4 lb
  • Variable Speed: No
  • Spindle Lock: Yes
  • Paddle Switch: Yes
  • Adjustable Handle: Yes
  • Tool-free Wheel Changes: Yes
Warranty
The Milwaukee Die Grinder 2680-20 comes with a 5-year limited warranty. This warranty covers the tool against any defects in materials or workmanship for a period of 5 years from the date of purchase. However, it's important to note that normal wear and tear or damage from misuse or abuse are not covered under this warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 286
