No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
6161-30-
Background
The Milwaukee Angle Grinder 6161-30 is a corded electric angle grinder. It operates at a voltage of 120V AC with a power of 13.0 Amps, and has a no-load speed of 9,000 RPM. The grinder is fitted with a 5/8"-11 spindle thread size and has a wheel diameter capacity of 6 inches. The tool length is 12-13/64 Inches and it weighs 5.7 lbs. The device has an 8 ft cord and uses a paddle switch with a lock-on feature.
The grinder is equipped with a motor that is suitable for heavy-duty grinding, cutting, and deburring tasks. It has an electronic clutch that safeguards the gears if the wheel binds up and an overload protection feature that aids in extending the motor's life by preventing overheating. The device has a soft start feature that reduces kickback when starting the grinder and a high capacity cooling system to keep the motor cool. It has L-shaped vents that help prevent debris from entering the motor. The grinder's design doesn't require tools for changing accessories, and it comes with an adjustable guard for quick angle adjustments. The paddle switch includes a lock-on feature for continuous operation.
Technical Specifications
  • Model Number: 6161-30
  • Product Type: Angle Grinder
  • Voltage: 120V AC
  • Power: 13.0 Amps
  • No Load Speed: 9,000 RPM
  • Spindle Thread Size: 5/8"-11
  • Wheel Diameter Capacity: 6 Inches
  • Tool Length: 12-13/64 Inches
  • Weight: 5.7 lbs
  • Switch Type: Paddle switch with lock-on feature
  • Cord Length: 8 ft
Warranty
The Milwaukee Angle Grinder 6161-30 includes a 5-year limited warranty. This warranty is designed to protect the buyer from any faults or defects that may occur with the product within this period. Although the exact coverage details are not mentioned in this specific context, limited warranties typically cover any defects in materials or workmanship that occur under normal use and maintenance. To claim the warranty, it's generally required to contact the manufacturer or authorized service provider, providing details about the issue and proof of purchase. Specific instructions might vary, so it's advisable to consult the warranty card or manufacturer's website for precise steps.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 234
