1 Diagram
Models
6142-30
Background
The Milwaukee 6142-30 angle grinder is an electrical tool used for cutting, grinding, and sanding. This tool operates on a 120V AC corded electric power source and has a maximum motor power output of 1,250 watts. The grinder's motor is capable of reaching a no-load speed of 10,000 RPM. It has a wheel diameter of 4-1/2 inches and a spindle thread of 5/8"-11. The grinder weighs 5.5 lbs and its dimensions are 3" x 1" x 2". It has a plastic housing, a paddle switch with lock-on, and employs spiral bevel gears.
The tool is equipped with several features for convenience and durability. It has a trigger grip handle for better control, debris baffles to protect internal components, and a 3-position side handle for optimal control. It also includes external brush doors for easy service access, a tool-free adjustable guard, and epoxy motor protection. Its multi-port exhaust system is designed to manage heat and remove debris, and it has a burst-resistant guard to minimize potential damage. This grinder is designed to reduce user fatigue during extended use, and the three-position side handle and paddle switch with lock-on maximize control and simplify continuous operation.
Technical Specifications
  • Power source: 120V AC corded electric
  • Motor power: 1,250 watts maximum output
  • No load speed: 10,000 RPM
  • Wheel diameter: 4-1/2 inches
  • Spindle thread: 5/8"-11
  • Weight: 5.5 lbs
  • Cord length: 8 ft
  • Dimensions: 3" x 1" x 2"
  • Housing material: Plastic
  • Switch type: Paddle with lock-on
  • Gear type: Spiral bevel gears
Warranty
The Milwaukee 6142-30 angle grinder comes with a warranty period of 3 years. The specifics of what is covered by the warranty are not detailed in the provided text, so it would be advisable to check with the manufacturer or retailer to understand the full extent of the coverage. To claim the warranty, it is typically necessary to provide proof of purchase and to contact the manufacturer or retailer directly, although the exact process is not specified in the given information.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 14
Past 7 Days: 33
Past 30 Days: 61
All Time: 875
