1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
6117-33D-
Background
The Milwaukee Angle Grinder 6117-33D is a handheld tool used for grinding (abrasive cutting) and polishing. This particular model, produced by Milwaukee Electric Tool Corporation, is primarily used for heavy-duty cutting and grinding tasks. It is equipped with a 750 watt, 120 V AC, 11 Amp motor, capable of no-load speed of 11,000 rotations per minute (RPM). The grinder has a disc diameter of 7 inches and a spindle thread of 5/8 inches - 11 threads per inch. It weighs 5.3 lbs and has an overall length of 12.4 inches.
One of the notable features of this model includes an overload protection system to prevent motor burnout. It is designed with a paddle switch with lock-on to provide comfort during extended use. The grinder also has a 2-position side handle for better control and maneuverability. Other features include a spindle lock for quick wheel changes and a sight window for visibility of wheel while making tool-free guard adjustments. The model also features an anti-vibration side handle to reduce user fatigue.
Technical Specifications
- Motor: 750 watt, 120 V AC, 13 Amp
- No load speed: 11,000 rotations per minute (RPM)
- Disc diameter: 7 inches
- Spindle thread: 5/8 inches - 11 threads per inch
- Weight: 5.3 lbs
- Overall length: 12.4 inches
- Cord length: 6 feet
Warranty
The Milwaukee Angle Grinder 6117-33D is offered with a 5-year limited warranty. This warranty specifically covers any defects that might arise in the materials or the workmanship of the tool throughout its lifetime. However, it is important to note that instances of normal wear and tear, misuse, or abuse of the tool are not included within the scope of this warranty.
