Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
Microsoft's Surface Laptop 13-inch (1st Edition) was announced on May 6, 2025, and released on May 20, 2025, alongside the Surface Pro 12-inch. It's a smaller, cheaper entry into the Surface Laptop lineup and effectively replaces the Surface Laptop Go line. It features a fanless 8-core Snapdragon X Plus processor with a neural processing unit rated at 45 TOPS. To hit its lower price, it uses a 60 Hz display, a fingerprint reader in the power button instead of a Windows Hello face camera, and removable UFS flash storage instead of an M.2 SSD. It also drops the Surface Connect port and charges via USB-C.
The Surface Laptop 13-inch starts at $899.99 and can be ordered in the following colors: Platinum, Ocean, and Violet.
Identification
The Surface Laptop devices all look very similar. You can identify your Surface Laptop model by the 4-digit number printed on the bottom of the device, near the display hinge. The Surface Laptop 13-inch with Snapdragon is identified by model number 2095. (A business-only variant with an Intel processor uses model number 2156.)
Refer to Microsoft's official guide for alternative ways to identify your Surface device.
Technical Specifications
Dimensions
  • 11.25 x 8.43 x 0.61 inches (285.7 x 214.1 x 15.6 mm)
Weight
  • 2.7 lbs (1220 g)
Display
  • 13” PixelSense touchscreen LCD
  • 1920 x 1280 (178 ppi)
  • Aspect ratio: 3:2
  • Contrast ratio 1000:1
  • Refresh rate: 60 Hz
  • 10-point multi-touch
Battery
  • 50 Wh Li-Po
  • Up to 23 hours of local video playback
  • Up to 16 hours of active web usage
Processor
  • Snapdragon X Plus (8 Core), passively cooled (no fan)
Memory
  • 16GB LPDDR5x RAM (soldered)
Storage
  • 256GB or 512GB removable UFS flash storage
Graphics
  • Qualcomm Adreno GPU
Cameras
  • Full HD 1080p front-facing camera
  • Windows Hello fingerprint reader in the power button (no face authentication camera)
Ports
  • 2 x USB-C / USB 3.2 ports with support for: charging and data transfer
  • USB-A 3.1
  • 3.5 mm headphone jack
  • No Surface Connect port — the device charges via USB-C only
Wireless
  • Wi-Fi 7
  • Bluetooth Wireless 5.4 technology
Additional Information
Author
with
Jeff Stephens
281,752 Reputation
0 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 3
Past 7 Days: 48
Past 30 Days: 244
All Time: 2,659
