Background and Identification
The Micromax A102 Canvas Doodle 3 is an Android smartphone released in April 2014 by Micromax Mobile, an Indian smartphone manufacturer and consumer electronics company. The phone is also known simply by its model number, A102.
The Micromax A102 Canvas Doodle 3 features a 6.0-inch display with a resolution of 480 by 854 pixels. It includes dual-SIM capabilities, meaning it can house two Micro-SIM cards and operate with one while the other is in standby. It comes with 8 GB of internal storage and 1 GB of RAM. Its internal storage can be expanded using separate microSDHC cards, which can be inserted into the dedicated microSDHC slot. The phone features a 5-megapixel main camera and a Video Graphics Array (VGA) selfie camera that is equivalent to approximately 0.3 megapixels. The Micromax A102 Canvas Doodle 3 also includes a 2500 mAh removable battery, meaning its battery is not attached to the inside of the phone with any kind of permanent adhesive, making repair and replacement easier than for non-removable batteries.
The phone includes the Android three-button navigation system with a ‘home’ button in the center of the phone’s bottom bezel (indicated with a house-shaped button), a ‘back’ button on the right side of the ‘home’ button (indicated with an arrow pointing to the left), and a ‘show-all-open-applications’ button on the left side of the ‘home’ button (indicated by a square). Micromax’s logo, featuring a balled-up fist with the fingers pointing forward that creates an image similar to a lower-case letter ‘m’ with an exclamation point, is positioned in the upper center of the phone’s backing.
Technical Specifications
Models: A102
Release date: April 2014
Body:
  • Dimensions and Weight: 166.4 x 84.5 x 9.8 mm (6.55 x 3.33 x 0.39 in), 202 g (7.13 oz)
  • SIM: Dual SIM
Display:
  • Type: TFT
  • Size: 6.0 inches, 99.2 cm2 (~70.6% screen-to-body ratio)
  • Resolution: 480 x 854 pixels, 16:9 ratio (~163 ppi density)
Platform:
  • OS: Android 4.2.2 (Jelly Bean)
  • Chipset: Mediatek MT6572 (28 nm)
  • CPU: Dual-core 1.3 GHz Cortex-A7
  • GPU: Mali-400
Memory:
  • Card slot: microSDHC
  • Internal: 8GB 1GB RAM
Main Camera:
  • Single: 5 MP, AF
  • Features: LED flash
  • Video: 720p
Selfie Camera:
  • Single: VGA
Sound:
  • Loudspeaker: Yes
  • 3.5 mm jack: Yes
Communications:
  • WLAN: Wi-Fi 802.11 b/g/n, hotspot
  • Bluetooth: 3.0
  • GPS: Yes, with A-GPS
  • NFC: No
  • Radio: FM Radio
  • USB: MicroUSB 2.0
Features:
  • Sensors: Accelerometer, proximity
Battery:
  • Type: Li-Ion 2500 mAh, removable
Miscellaneous:
  • Colors: Blazing Blue, Pristine White
Additional Information
Geoff Wacker
93,075 Reputation
88 Guides authored
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 80
All Time: 13,907
