Up to 20% off select tools
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
CM-1400-HDEC1
Background and Identification
This electric pressure washer is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment. Pressure washing, sometimes called power washing, is a method of spraying high-pressure water or detergent mixture to blast off dirt, paint, or other materials from a surface.
This pressure washer can be mounted onto a frame for portability, or used as a stationary washer. Please note that when the pressure washer is attached to the frame, it is usually referred to by model number CM-1400-0MEC.
To function, it must be attached to a water source and plugged in to an electrical outlet. It is fairly lightweight, and is recommended for use by homeowners or small businesses for their pressure washing needs. This may include outdoor furniture, screens, and vehicles.
This machine has several notable features. The spray pattern is adjustable from a 0° straight line to a 60° wide spray. There is also a detergent injector built into the machine, and the engine is completely enclosed to protect it from water damage.
Technical Specifications
  • Net Weight: 45.00 lbs
  • Dimensions ( L x W x H): 14 x 11 x 10 in
  • PSI: 1400
  • GPM: 1.5
  • Horsepower/Motor: 1.5 HP, 120V, 1Ø, 13.5A
  • Pump: Triplex Crankshaft
  • Unloader: Adjustable Pressure
  • Plug Type: NEMA 5-15P
  • Lance: 36 in
Additional Information
Mi-T-M Product Page
Home Depot Rental (with frame)
Pressure Washing - Wikipedia
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 79
All Time: 6,908
