3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
CA-3504-HDHB1
Background and Identification
This gas-powered pressure washer is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment. Pressure washing, sometimes called power washing, is a method of spraying high-pressure water or detergent mixture to blast off dirt, paint, or other materials from a surface.
This pressure washer can reach a pressure of 3500 pounds per square inch (PSI) using the Honda GX390 engine. The frame is made of aluminum to make it more lightweight and portable. There are also three nozzle options, which create a spray pattern at 0°, 15° or 25° as needed. This allows the user to adjust the width of the spray for detailed, accurate cleaning at a small angle or better area coverage with a larger angle.
Note: The manufacturer, Mi-T-M, refers to this model with the number CA-3504-1MAH. However, the Home Depot rental page refers to it as CA-3504-HDHB. Whether this is because Mi-T-M changed the model numbering or because Home Depot uses a unique numbering system is unclear.
Technical Specifications
  • PSI: 3500
  • GPM: 3.5
  • Engine: Honda GX390
  • Pump: AR
  • Mi-T-M No.: 3-0310
  • Unloader: Mi-T-M, Adjustable Pressure
  • Lance: 48 in.
  • Net Weight: 125.00 lbs.
  • Shipping Weight: 175.00 lbs.
  • Length: 42.50 in.
  • Width: 23.50 in.
  • Height: 24.50 in.
Additional Information
Mi-T-M Product Page
Home Depot Rental Page
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 1,343
