Up to 20% off select tools
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
CA-2703-HDHB
Background and Identification
The Mi-T-M Pressure Washers CA-2703-HDHB is a 2000 - 3000 PSI gasoline-powered pressure washer. It includes a 5.5-horsepower Honda GX200 engine. This pressure washer is designed to remove old and peeling paint or mold and mildew from a variety of surfaces.
The Mi-T-M Pressure Washer CA-2703-HDHB is a cold water pressure washer that has a water flow of 2.4 gallons per minute (GPM). It can be attached to normal garden hoses, but can also be used for more heavy-duty jobs. It features 6480 cleaning speeds with an adjustable pressure unloader.
The Honda General Purpose Motor model GX200UT2 is an air-cooled, four-stroke, overhead-valve engine. The model GX200UT2 displaces 196 cubic centimeters (cc) and produces a net power output of 5.5-horsepower at a speed of 3600 revolutions per minute. The engine produces a net torque of 9.1 foot-pounds at a speed of 2,500 revolutions per minute. It can hold up to 0.83 gallons of gasoline and 0.63 quarts of engine oil. Honda recommends using unleaded 86 octane or higher fuel for this engine.
The CA-2703-HDHB model’s frame is aluminum and is not painted. The frame includes two pneumatic front wheels and a rounded handle. The name “Mi-T-M” is printed in white font on the front of the pressure washer’s front. The washer’s engine includes the name “Honda GX200” in red font printed at the front of the machine.
Technical Specifications
Engine:
  • Engine Brand: Honda GX
  • Starter: Recoil
  • HP: 6.5 HP
  • Consumer Engine Warranty: 2 Years
Pump:
  • Pump Brand: AR
  • Pump Type: Triplex Plunger
  • Adjustable Pressure: Yes
  • Water Temperature: Cold
  • Consumer Pump Warranty: 7 Years
  • Water Pressure: 2700 PSI
  • Water Flow: 2.4 GPM
Housing:
  • Frame Type: Aluminum
  • Wheels: Pneumatic
Hose:
  • Hose Storage: Hook
  • Hose Length: 50 Feet
  • Hose Material: Rubber
  • Hose Diameter: 3/8 Inch
  • Hose Connections: Quick-Connect
Spray Gun:
  • Spray Gun Connection: Quick-Connect
  • Spray Gun Grade: Professional
  • Spray Gun Wand: Single Wand
  • Spray Tips: Quick Connect Tips (3)
  • Turbo Nozzle: Sold Separately
Overview:
  • Weight: 76 Pounds
  • Made in USA: Yes
  • Consumer Warranty: 1 Year
  • Product Length: 39 Inches
  • Product Width: 20.5 Inches
  • Product Height: 24.5 Inches
  • UPC: 016977016692
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 93
All Time: 4,593
