Guides
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
CA-2703-HDHB1
Background and Identification
This gas-powered pressure washer is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment. Pressure washing, sometimes called power washing, is a method of spraying high-pressure water or detergent mixture to blast off dirt, paint, or other materials from a surface.
This portable pressure washer is a professional-grade machine, and can be used for light-to-medium duty tasks. This includes surface preparation, concrete cleaning, and outdoor restoration projects as well as vehicle cleaning and other operations. For safety, you should only use this machine in an outdoor setting that is well-ventilated, and follow all safety guides that are offered by the manufacturer.
This pressure washer can be referred to by two different model numbers: CA-2703-HDHB1 or CA-2703-1MMH.
Technical Specifications
  • Pump Rebuild Seal Kit Part Number: 70-0501
  • Engine: Honda GX200
  • Assembled Depth: 39 in
  • Assembled Height: 20 in
  • Assembled Width: 24 in
  • Weight: 73 lbs
  • Pressure: 2700 PSI
  • GPM: 2.4
  • Pump Type: Direct drive triplex piston AR Pump
  • Nozzles:15, 25 and detergent quick connect nozzles
  • Hose: 50' x 3/8" hose
  • Lance Size: 36"
Additional Information
Home Depot Rental
Mi-T-M Product Page (note: uses a different model number)
Pressure Washing - WIkipedia
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 64
Past 30 Days: 312
All Time: 19,043
