1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Background and Identification
This pressure washer accessory is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment. Pressure washing, sometimes called power washing, is a method of spraying high-pressure water or detergent mixture to blast off dirt, paint, or other materials from a surface.
This is a pressure washer extension wand that goes from a minimum length of 6 feet, 8 inches to a maximum length of 18 feet. It is intended to be used to clean difficult-to-reach places like the eaves of a house or multi-story buildings without the operator needing to climb and balance on a ladder while they use the pressure washer. This extension is compatible with all Mi-T-M pressure washers up to 4000 PSI, and with water up to a temperature of 200 degrees Fahrenheit.
This extension has several siblings, including extensions that reach 12 feet or 24 feet, and aluminum and telescoping versions. All of these variations are listed on the Mi-T-M Product Page, and they share an operating manual To use this or any other extension safely, you should read through the operating manual and follow all safety guidelines given by the manufacturer.
Technical Specifications
  • Min. Length: 6 ft 8 in
  • Max. Length: 18 ft
  • Shipping Dimensions: 80 in. x 8 in. x 3 in.
  • Shipping Weight: 13.4 lbs.
  • Water Temperature Compatibility: Up to 200°F
Additional Information
Mi-T-M Home Page
Product Page
Home Depot Rental
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 2,667
