Up to 20% off select tools
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
CM-1400-HDEC
Background and Information
The Mi-T-M electric pressure washer is manufactured by Mi-T-M, an equipment manufacturer that sells a variety of machines for industrial, commercial, and residential use. Their products include pressure washers, portable heaters, generators, air compressors, and other equipment.
This pressure washer is intended for use on light-duty projects such as cleaning vehicles, driveways, or outdoor equipment and furniture. It is capable of spraying water at up to 1400 PSI (pounds per square inch), and should therfore be operated carefully. The user should never allow the water spray to hit any person, including themselves, as the high pressure jet of water can cause serious injury.
The Mi-T-M pressure washer is CSA Safety Listed. This means that it has been tested and certified by the CSA organization in compliance with safety standards for the type of tool and the country that the tool can be purchased in. CSA stands for Canadian Standards Association, but they test products to meet a variety of safety standards set by different countries.
Technical Specifications
  • Depth: 40 in
  • Height: 18 in
  • Width: 33 in
  • Weight: 60 lbs
  • Pressure: 1400 PSI
  • 1.5 GPM
  • Motor: 1.5 hp, fan-cooled
  • 15, 25 and detergent quick connect nozzles
  • 50' x 3/8" hose
  • Trigger gun and 36" lance
  • CSA Safety Listed
Additional Information
Home Depot Rental
Operating Manual
Pressure Washing - Wikipedia
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 95
All Time: 11,123
