No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Models
CBA-3504-HDHB
Background
The Mi-T-M Pressure Washer CBA-3504 is a pressure washer that utilizes a gasoline engine. It is intended for use in both residential and commercial environments, providing a cleaning solution for exterior surfaces like siding, decks, sidewalks, driveways, vehicles, and farm equipment.
This pressure washer operates with a maximum pressure of 3500 PSI and a flow rate of 3.7 GPM. It is powered by a 389cc Honda GX390 OHV air-cooled gasoline engine. The unit employs a belt-driven AR crank pump with brass manifold and thermal protection, with power transmitted via a V-belt drive. The pump seal is made of ceramic/carbon. The device includes downstream chemical injection for detergent application, and comes with a variety of high-pressure quick-connect spray nozzles. The pressure washer features a 50 ft steel wire braided high-pressure hose and a 48" wand with a rubber grip. The frame is made of corrosion-resistant aluminum and the unit dimensions are 30" x 24" x 40". It weighs 140 lbs when dry and has a fuel tank capacity of one gallon.
Technical Specifications
  • Pressure: 3500 PSI max
  • Flow rate: 3.7 GPM
  • Power source: 389cc Honda GX390 OHV air-cooled gasoline engine
  • Pump: Belt-driven AR crank pump with brass manifold and thermal protection
  • Power transmission: V-belt drive
  • Pump seal: Ceramic/carbon
  • Detergent injection: Downstream chemical injection
  • Nozzles: 0°, 15°, 25°, 40° high pressure quick connect spray nozzles
  • Hose: 50 ft steel wire braided high pressure hose
  • Wand: 48" wand with rubber grip
  • Gun: Professional-grade trigger gun with safety lock-off
  • Frame: Corrosion resistant aluminum
  • Dimensions: 30" x 24" x 40"
  • Dry weight: 140 lbs
  • Fuel tank capacity: 1 gallon
Warranty
The Mi-T-M Pressure Washer CBA-3504 is accompanied by a one-year limited warranty. This warranty coverage is provided by the manufacturer, Mi-T-M Corporation. The warranty ensures the product against any possible defects due to workmanship or materials used. To claim the warranty, the owner needs to provide proof of purchase and contact the manufacturer directly. The details regarding the process may be found in the product's user manual or the manufacturer's website. Please note, any misuse, unauthorized modifications, or failure to follow the recommended maintenance procedures may void the warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 573
