Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Documents
Background and Identification
The Medumat Standard A is a compact, portable machine used to provide emergency ventilation to patients. Users can customize Medumat Standard A’s air mix, respiratory frequency, minute volume, and maximal ventilation pressure to administer medical aid to patients in varying states of emergency.
The Medumat Standard A will produce acoustic and visual alarm if it encounters stenosis, disconnection, decrease in oxygen pressure, low battery, system failure, or the patient does not trigger when the device is in “assisted ventilation” mode. The device will continue to alert the user until the cause of the problem is eliminated.
The Medumat Standard A is powered by a lithium-ion battery and does not rely on an outside charging source. The expected service life of the Medumat Standard A is two years.
The Medumat Standard A weighs 2.4 pounds and its dimensions are 7.4 inches by 4.3 inches by 3.5 inches.
Technical Specifications
  • Dimensions:   190 mm x 110 mm x 90 mm
  • Weight:  Approx. 1.1 kg
  • Temperature (operating conditions): -18 °C to +60 °C
  • Height above sea level (operating conditions): -500 to 3 000 m
  • Degree of protection against ingress of solid foreign bodies, ingress of dust, and ingress of water with harmful effect: IP24
  • Resistance to shock and vibration: EN 1789, EN 794-3, ISO 10651-3, and RTCA DO-160
  • Power supply: No external power supply required
  • Battery replacement interval: 2 years
  • Ventilation modes (standard): IPPV and SIMV
  • Monitoring: Airway pressure
  • Other functions: Assisted ventilation
  • FiO₂: AirMix (approx. 60%) or 100%
  • Tidal volume: 75 ml to 4 000 ml
  • Ventilation rate: 5/min to 40/min
  • I:E: 1:1,67; Between 1:1 and 1:2,33 in assisted ventilation.
  • PEEP: 2.5 to 10 mbar via external PEEP valve
  • Further standards used: EN 60601-1, EN 60601-1-2, EN 794-3 and ISO 10651-3
  • Source: The Medumat Standard A Brochure
Additional Information
Medumat Sevice Manual
MEDUMAT Standard a Ventilator WM 22800
MEDUMAT Standard a Ventilator Description and instructions for use
WEINMANN MEDUMAT Standard a 呼吸设备说明和使用说明
Author
with
Jeff Stephens
281,737 Reputation
0 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 45
All Time: 1,176
