Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background Information
The Medumat Easy CPR Ventilator is the smallest ventilator that Weinmann offers. The Medumat series was first sold in 1972. In 1997 Weinman released the most current version, which includes improved security measures. They now have alarm systems that monitor the patient’s breathing and alert when any inconsistencies are detected.
You can identify this ventilator by locating its name, “MEDUMAT EasyCPR “, on the top right corner of the control panel. The control panel is mainly black with a light gray stripe on the right side. You can find a dial to adjust ventilation pressure, a pressure indicator in the form of a vertical bar graph on the top left corner, the on/off button in the bottom right corner, and a tube/mask ventilation switch button in the bottom left corner of the control panel. The body of the ventilator is an off white color. This device is rectangular in shape and is made to be mounted in a portable life base system. There is a ventilator hose connector located on the bottom of the device; the connector joint makes a 90 degree angle. Additional device information can be found on the device information plate, which is located on the right side of the device in front of the speaker.
The device information plate contains:
  • serial number
  • manufacturing year
  • battery type
  • disposal method
Technical Specification
  • Dimensions: 100 x 145 x 90 mm
  • Weight: 0.7 kg
  • Temperature
    • For Operation: -20 °C to +50 °C
    • For Storage: -40 °C to +70 °C
  • Oxygen Concentration: 100%
  • Gas Supply: Medical Grade Oxygen
  • Gas Consumption for Internal Management: 0 I/min
  • Operating Pressure: 2.7 bar to 6 bar
  • Minimum Input Flow: 40 I/min
  • Power Supply: Lithium Iron Battery (3.6 V; 5.2 Ah)
    • Battery runtime up to 100 h under standard conditions
Additional Information
Medumat Easy CPR Ventilator Device Page
Medumat Easy CPR Ventilator Device Training Video
Medumat Easy CPR Ventilator Device Brochure
Medumat Easy CPR Ventilator Purchase Information
Medumat Easy CPR Ventilator Supply Catalog and Replacement Parts (Pg. 69-79)
MEDUMAT Easy CPR Ventilator
MEDUMAT Easy CPR Ventilator WM 28140 Service and Repair instruction
Author
with
Jeff Stephens
281,737 Reputation
0 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 40
All Time: 842
