14 Diagrams
Documents
Models
G6100R
Background and Identification
The Makita Generator(Model G6100R) was released and manufactured in 2010 to help many families, small businesses, and other mediums prevent any power outages if under circumstances such as storms, tornadoes, hurricanes and be assured that they have the power to keep any necessities running! With 5800 watts you can be assured at least 7 hours of run time from the generator. The generator itself weighs 172 pounds and measures by 26.8-by-18.5-by-24.4 inches (Length x Width x Height)
The generator is a teal color and is surrounded by black handles/base. The specific model number for this generator should read ‘Generator G6100R’. The model number should be located at the very front of the generator right next to the name of the brand and the dials of the generator, if you have any questions please look at our device photo for reference.
Makita has two generators in the G6100R series the G6100R and the G6101R but they both share many of the same specifications as you’ll see on the user manual so working on one or the other should be very similar.
Maintenance Schedule
PROCEDURE AND INTERVAL
1) Change engine oil: Initial 20 hours and every 100 hours afterward
2) Clean air cleaner (element) : Every 50 hours
3) Replace air cleaner element: Every 200 hours
4) Clean/adjust spark plug and electrodes: Every 200 hours
Note: More frequent maintenance may be necessary under dusty, dirty, or severe conditions
Technical Specifications
Model (G6100R) - Alternator
  • Type
    • Brushless, Self-Exciting, 2-Poles, Single Phase
  • Voltage regulator
    • Condenser type
  • Rated voltage (60Hz)
    • 120 V/ 240 V
  • Maximum output (60Hz)
    • 5.8 kW
  • Rated output (60Hz)
    • 4.8 kW
  • Rated power factor
    • 1.0
  • DC output
    • 12V-8.3A
  • Over-current protector
    • No-fuse Breaker
Engine
  • Model
    • Robin EH34D
  • Type
    • Forced air-cooled, 4-cycle, Gasoline Engine
  • Displacement
    • 338 cm^3
  • Fuel
    • Automotive unleaded gasoline
  • Fuel tank capacity
    • 5.68 US-gal (21.5 liters)
  • Rated continuous operation (Approx.)
    • 7.0 hours
  • Starting system
    • Recoil (Electric starter)*
Dimensions
  • Length
    • 26.8 in. (680 mm)
  • Width
    • 18.5 in. (470 mm)
  • Height
    • 24.4 in. (619 mm)
Misc. Specifications
  • Dry weight
    • 35.3 lb (78 kg)
  • Valve clearance (Intake and Exhaust)
    • 0.0039 ± 0.0006 in.(0.1 ± 0.015 mm)
  • Emissions Durability Period (California only)
    • 500 hours
Additional Information
List Of Each Component And Where To Find/Buy Them
Makita G6100R Generator - Answered Questions & Fixed issues Forum
Youtube video: Makita Generator G6100R Starting Procedure
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 79
All Time: 3,869
