1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
9566CV
Background
The Makita 9566CV is a 6" SJS™ Cut-Off/Angle Grinder designed for stone grinding, polishing, and cutting. It features a 13 AMP motor with a variable speed control dial, allowing customization to the task at hand. The grinder is built with Makita's innovative SJS™ mechanical clutch system, which protects the gears and prolongs tool life. Additionally, it has a soft start, labyrinth construction for motor protection, and protective zig-zag varnish to seal the motor and bearings from dust and debris. The dimensions of the grinder are H 4 in, W 5.5 in, D 11.75 in, with a 6" max wheel diameter and 1/4" max wheel thickness.
Technical Specifications
  • Motor: 13 AMP
  • Variable Speed Dial: 4,000 - 10,000 RPM
  • Max Wheel Diameter: 6 inches
  • Max Wheel Thickness: 1/4 inch
  • Dimensions: H 4 x W 5.5 x D 11.75 inches
  • Weight: 5.3 lbs
  • Spindle Type: 5/8" - 11 UNC
  • Switch Type: Body grip/slide
Makita 9566CV Instruction Manual
Makita 9566CV Parts Breakdown
Makita 9566PC Parts Breakdown
Makita 9565CV Parts Breakdown
Makita 9566CV 150 mm Angle Grinder Instruction Manual
Makita 9566CV 6-Inch Angle Grinder Exploded Parts Diagram
Makita 9566CV Cut-off / Angle Grinder Instruction Manual
Makita 9566CV Cut-off / Angle Grinder Instruction Manual (EN, FR, ES)
Makita 9566CV 6-Inch Angle Grinder Parts List
Makita 9566C and 9566CV 1,400 W Angle Grinder Product Brochure
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 57
All Time: 424
