1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
9565CV
Background
The Makita 9565CV is a 5" SJS™ Angle Grinder designed for stone grinding and polishing tasks. This tool is equipped with a 13 AMP variable speed motor and soft start technology for smoother activations. A 5-stage variable speed dial (2,800 – 10,500 RPM) allows you to match the RPM to the specific task. The SJS™ mechanical clutch system safeguards the gears for prolonged tool life, and the electronic limiter halts the motor to reduce accidental motor overload. The electronic speed control ensures consistent speed during use. The lock-on switch and side handle offer convenient operation. The 9565CV is suitable for various stone work tasks, including polishing and grinding.
Technical Specifications
  • Wheel Diameter: 5"
  • AMPS: 13
  • No Load Speed (variable speed): 2,800 - 10,500 RPM
  • Spindle Type: 5/8" - 11 UNC
  • Lock-On Switch: Yes
  • Lock-Off Switch: No
  • Switch Type: Body grip/slide
  • Overall Length: 11-3/4"
  • Net Weight: 4 lbs.
  • Variable speed dial: Yes
  • Power Type: Corded
  • Bind-Up Control: Yes
  • Shipping Weight: 7.4 lbs.
Warranty
The Makita 9565CV angle grinder comes with a 1-year warranty.
Makita 9565CV Angle Grinder
Makita 18v LXT X2 Angle Grinder Reference Guide
Makita 9565CV Parts Breakdown
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 478
